Old 07-28-2008, 06:14 AM
dan385 dan385 is offline
dan385 is on a distinguished road
Default Start up/Wait light
3 times in the last month I''ve had an issue with start up. After running my Humvee for 20 minutes or so and then trying to start it again an hour or so later, I turn the key on and the wait light doesn't come on. I wait a few seconds, try to start it and it turns over but doesn't start. I wait between an hour and overnight and it'll start again. It's never done it when the truck's been sitting for several days, starting right up without issue. I looked at the protective control box...it looks pretty new. Anyone had this issue? (1986 M998)
Old 07-28-2008, 01:22 PM
audiofetish's Avatar
Default Re: Start up/Wait light
First thought says the glow plug controller. Have you converted your truck to 12 volt or is it still 24? If it is 12 here is some good tips http://flashoffroad.com/Diesel/GlowP...elGlowplug.htm If you are still running on 24 I am sure some others will step in and help more than I can....
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
Old 07-28-2008, 03:31 PM
It's 24v...hopefully gonna have somebody check it out next week...
Old 08-19-2008, 02:27 AM
phazer42 phazer42 is offline
phazer42 is on a distinguished road
it sounds like you have a bad Glow plug controller.... its locatedon the water jacket near the t-stats.... has a bunch of wires going to it (6 I believe)... you have three options....
1. replace the glow plug controller and it will fix it, but it will occur again
2. hard wire the glow plug controller to a button that you dictate when to operate the glow plugs
3. get a KDS control box that will not use the GPC, rather always cycle the glow plugs....
Old 08-30-2008, 06:55 AM
Thanks. I plan on replacing the pcb, glow plugs and controller. I'll let ya know how I make out.
