Old 12-26-2008, 03:50 PM
GS345 GS345 is offline
GS345 is on a distinguished road
Default Bad rattle question
When I am driving against the wind, there seems to be a rattle in the dash, can't seem to exactly locate it. It only seems to be around 70 mph into the wind. Any ideas on what it is? My worry is if wind can get in..... so can rain.
thanks,
Jeff
Old 12-26-2008, 05:06 PM
Default Re: Bad rattle question
search for:
windshield rattle or windshiled air leak
dash rattle
Also check your sunroof deflector to see if it is tight.
Sounds like the windshield air leak deal. Also check your a pillar outside covers to see they are tight. I used to 3M tape mine down.
Old 12-26-2008, 06:02 PM
Easy Ed Easy Ed is offline
Info on pillar repair.
http://www.elcovaforums.com/forums/s...ad.php?t=16756
Ed
Old 12-26-2008, 07:38 PM
Thanks for the info. I am getting a list together and am about to take it to the dealership for some other small issues. Just wanting to find out if it is a known problem or if I was the first
Old 12-26-2008, 09:39 PM
Intercooled's Avatar
Intercooled is off the scale
I had that vibration noise as in my 05H2. Drove me crazy. I didnt deal with it because I leased it. My 06 is fine, no problems.
2006 H2 SUT Fusion Orange LE
Old 12-27-2008, 02:33 PM
HummerMann's Avatar
I had the same thing. I'll bet it's the pillar post covers on the windshield. They vibrate so much it affects the dash. This is a common H2 problem. The dealers now use a tape-mastic combination which solves the problem. If you're handy open the door, pull the rubber trim off, unscrew the three phillips screws and pop off the simulated air cleaner bulges behind the hood ( you need them off to get the plastic pillar posts completely off so you can clean the windshield thoroughly before you put down mastic). Use a high grade epoxy mastic and you'll be in business. Since their is a GM TB out on this, the dealer "may" do it for free.
Mine did it around 65 and at first I thought it was the sunroof deflector, but I found on this forum it's a common problem and it can buzz your dash too.
Hummer, like nothing else
