Old 09-27-2008, 04:15 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Default Tranny Overfilled!!
Because I'm getting ready to install a heavy duty external transmission cooler on the H2, I took the H2 to our local dealership a couple of days ago for a transmission flush, mainly to flush out the old Dextron III and replace it with Dextron VI (the vehicle has 45K miles on it and the previous owner never had the 30Kmi. service performed).
So yesterday after driving a few miles to warm the tranny up I checked the tranny fluid level and it's overfilled to the point where the level on the dipstick is about an inch above the cross hatched HOT full mark. Is it possible that this can damage the tranny in any way... blow out a seal or something? If this is nothing to worry about I would surely like to know. But it occurred to me that I could take some tubing and put it down the the filler/dipstick opening and siphon the excess fluid out. How much fluid would an inch on the dipstick represent?
BTW, taking the H2 back to the (incompetent) stealership is not an option, it's a 100mi. round trip from where I live.
Old 09-28-2008, 01:21 AM
Metallic Red's Avatar
Metallic Red Metallic Red is offline
Metallic Red is on a distinguished road
Default Re: Tranny Overfilled!!
If your planning to install a cooler, you might lose some fluid anyway, so put your cooler on and check it again.
If you didn't notice any fluid dripping out the vent on the trans I would say your probally ok. But I wouldn't drive it to much until you put that cooler on or drain a little. Hope this helps. Good Luck!
2004 Hummer H2 " Metallic Red "
20 inch Mojave's (Teflon)(325/60/20) BFG A/T's
MagnaFlow kitty back...Hypertech Tuned..Music to my ears
HCMI Member 50043
Old 09-28-2008, 04:24 AM
SummitUp's Avatar
Well the cooler install is still a week or so away, so I found some teflon tubing I had in the garage and I put it down the the filler/dipstick opening and siphoned some of the ATF out. It only took a few minutes and it turned out the tranny was about a quart and a half over filled! Go figure...
Old 10-01-2008, 06:52 AM
AK47's Avatar
AK47 AK47 is offline
AK47 is on a distinguished road
Hi The fact is that the tranny will work more efficient ,with half inch more fluid in it i my self have upgraded the cooler over a year ago i am still running on drexon 3 but have well over here 1cm on hot above full line
Grant Ryeback
www.euroco-corp.com
http://www.hummertruckworld.com/EUROCO/
00423663114587
