Old 05-09-2008, 03:45 PM
wulf wulf is offline
wulf is on a distinguished road
Unhappy trans probs
trying to get advise on 2005 h2 transmission ! initially the box would shift fine in manual but not at all in d and it was very slugish on pull away as if it was sticking in top then last week the trans let go big style locking in gear ! i have just replaced the transmission and am somewhat disturbed to find it also isn`t shifting in auto but is fine manually it is setting dtc`s for torque converter clutch,shift solenoid a+b and shift timing solenoid i have checked appropriate fuses and pink wire to box and all ok also stripped back loom from box to pcm and there is no sign of damage unfortunately i don`t have a local authorised dealer so any help would be great
Old 05-09-2008, 10:26 PM
Default Re: trans probs
IGNITION SWITCH??
Old 05-17-2008, 01:35 AM
IRA51's Avatar
IRA51 IRA51 is offline
who rebuilt the trans ? or did you put a junk yard trans in ? if you had it rebuilt and installed by a shop ,bring it back and tell hem to fix it . if you installed it unplug every eletrical conection and clean them with eletric parts cleaner and put some dieletric grease on them and reconect them . some times it is as simple as that .
A government big enough to
you have.
-- Thomas Jefferson
Old 05-26-2008, 10:06 PM
ignition switch, orig trans most likely ok(unless you got it hot by taking off in 3rd)
Old 01-15-2009, 01:25 PM
Talking Re: trans probs
sorry its taken so long to get back but you were quite correct it was the ignition switch replaced it and been fine ever since thank you chaps
