Old 12-02-2008, 02:31 AM
jash3 jash3 is offline
jash3 is on a distinguished road
Question doors speaker remover
How do I remove the door speaker in my H3
Old 12-02-2008, 03:46 AM
H3slate's Avatar
H3slate H3slate is offline
Default Re: doors speaker remover
On your door handle there is a plastic piece you have to remove to gain access to the screws holding your door on. There should also be one in the inside door handle. After the screws are removed, you need to pop the door panel off the retaining brackets? . There will be some wires to deal with, but then you can replace your door speaker.
