11-14-2008, 04:33 AM
Getting tires mounted
I need help finding someone on Long Island that is capable of mounting my 37/13.50/17 Toyo open country's tires on my 17x12 Weld racing method wheels. So far no luck even went to the local truck shop that deals with lifted trucks and they were also unable to do it. Any help would be greatly appreciated. Here are a few pictures of the wheels.
"A clear conscience is usually the sign of a bad memory."
03 White H2
12 HID lights, factory lightbar, custom light bar for brush guard, OEM luggage rack, k&n intake, Gran MAF, 37" Toyo M/T's, 17x12 weld racing wheels, predator programer, Dynomax 4" catback exhaust,
02 10th Anniversary H1 #44 Will be missed
94 Custom pearl white H1(work in progress)
Too many mods to list
06 kawasaki stx-15f
02 yamaha superjet
02 polaris scrambler 500
12-02-2008, 01:43 PM
Re: Getting tires mounted
Anybody. Any info would be greatly appreciated. Even if not from new york area just some info on getting tires mounted on 12" wide rims. Difficulty of finding someone to mount them and cost.
03 White H2
06 kawasaki stx-15f
02 yamaha superjet
12-02-2008, 06:43 PM
I would check with your dealership. No one local to me (NTB. Merchants) was capable of doing 35s let alone 37's.
I'm Gonna crazy you my body
12-04-2008, 05:46 PM
I don't think they have an issue with the size of the tire. That tire is not designed to fit on a 12" wide wheel and they don?t want to be liable. Toyo's have very thick side walls and they are designed to fit a 8.5 -11" wide wheel. It will be hard as hell to seat the bead. I talked to a buddy of mine who makes wheels for a living and he agrees that these are not a good match. If and when you do get them on, you will be adding a lot of extra stress on the sidewall of the tire and if you ever air them down for offroading you will bust the bead very easily. Here is a link to Toyo?s specs http://marktg.toyotires.com/file/18136.pdf
Hope this helps
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
12-06-2008, 06:12 PM
Going too wide on rims is as pobably more dangerous than too narrow. Loosing the bead when depressurizing and excessive sidewall flex will cause uneven wear and possible overheating and blow outs in hot summer weather.
Those are beautiful rims, but driveability is going to suffer.
Hummer, like nothing else
12-06-2008, 07:42 PM
Thanks guys. I was going to get a set of staun bead locks for the wheels because of the airing down issue. I guess I'm SOL.
03 White H2
06 kawasaki stx-15f
02 yamaha superjet
