Old 11-27-2008, 06:33 AM
ehaser ehaser is offline
ehaser is on a distinguished road
Default Need advice.. Rockstar 22x12 on 37x12.5 bfg km2's
Does anyone know if I can run these stock? Is there a particular offset that I need. I like the 20x10 size but I'd rather have a little more wheel. Since they don't make a 22x10 so I have to go with the 22x12 on a the 37x12.5. I believe that the bfg km2's are actually 36.5 in diameter so that should help me fit stock. Does anyone have an Idea if these are going to rub?
Old 11-28-2008, 11:22 PM
Default Re: Need advice.. Rockstar 22x12 on 37x12.5 bfg km2's
anyone? I'd love to get my set up asap.
Old 12-01-2008, 07:06 AM
8500lbs's Avatar
8500lbs 8500lbs is offline
8500lbs is on a distinguished road
From what I hear this setup is not possible untill this summer or so, why you ask? from what I have found the KM2's are not going to be available in the R22 size untill then only up to a 20 inch for now. Maybe that is just around here though. other than that i am running 22's with 37 BFG's MT right now. They are the orginal version that looks more like the Krawler tires than the MT's they are 13.50 wide and i have very minimal rubbing on full steering lock. The tires are great and if i cant get the KM2's in time then i am going to have to get the BFG M/T again.
Old 12-01-2008, 05:15 PM
brad_p's Avatar
brad_p brad_p is offline
I have the 37x12.5 km2's on my h2 with a slight tbar raise. Get a little plastic rub on a hard turn. THe Km2's look like the Krawlers not the original m/t's. Although BFG releases a tire that was a mud terrain that was only made for 22's it is the reason the km2's were released. I dont know the name off the top of my head but its a bfg mud terrain that looks almost identical to the km2's and was for only for a 22 inch rim. A guy at the local 4x4 parts place has them on a Lifted f150 with 22 inch jessie james rims.
----------o-o-o-o-
[[_]|[]|[][___]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
Old 12-02-2008, 02:57 AM
Thanks guys..I really like the way the 22's look with a lower profile m/t like the grappler however I can't have something that aggressive. I use my truck for work a lot so I need something that I can use on the street without sounding like a old bi-plane.. I noticed that the procomp xtreme m/t's come in a 35x12.5 r 22.. That's bad ass. The only problem is that the rockstars that I wanted only come on a 9.5 or 12.. why can't they make a 10-11 in the 22! damn. Maybe I'll go with the Hulk's.. I'm also a little worried that I won't fit into my garage.. It's only 79inches tall. I've already removed the roof rack.
