Old 05-04-2009, 08:12 AM
Ztoe's Avatar
Ztoe Ztoe is offline
Ztoe is on a distinguished road
Default NOISY FRONT LEFT TIRE/SUSPENSION
1999 WAGON I HAVE HAD IT SINCE IT WAS ALMOST NEW 3400 MIILES I NOW HAVE 45000 AND I WAS RUNNING PJ DIRT GRIPS 37X12.5X16.5 AND SEEMED TO BE WORKING FINE THEN MED-VED HUMMER IN CASTLE ROCK COLORADO ROTATED AND BALANCE ABOUT 18 MONTHS AGO AND I HAVE HAD A SHIMMY AT SPEED EVER SINCE EVEN A CLUNKING KIND OF NOISE I HAVE HAD MY OWN CERTIFIED HUMMER MECHANIC LOOK AT IT AND HE SEES NOTHING WRONG W/ THE FRONT LEFT COMPONENTS I REMENMBER READING ABOUT HOW WEAK THE STEERING COMPONENTS ARE HOW OFTEN DO YOU NEED TO CHANGE THE IDLER ARM OR OTHER STEERING COMPONENTS I JUST HAD SOME 37X12.5X16.5 MTR MOUNTED AND BALANCED BY DISCOUNT TIRE IT SEEMS BETTER BUT STILL SOME CLUNKING NOISE IN THE LEFT FRONT END I GET NO FEEDBACK IN THE STEERING WHEEL ANY INPUT WILL HELP
JIM PETTET
1999 H1 Wagon
1979 Mercedes Unimog U900
Couldnt Decide Which was King Of Off Road So Got Both
Old 05-04-2009, 03:09 PM
audiofetish's Avatar
Default Re: NOISY FRONT LEFT TIRE/SUSPENSION
There is no exact mileage to replace components. This link will show you how to check most components http://flashoffroad.com/Maintenance/.../alignment.htm
Also, this may sound dumb but the clunking could very well be your hood. The hood snubbers go out over time and will cause clunking over bumps and things. RuberDuck4x4 sells a new kit for $50. You might want to check that out.
JIM PETTET
09 Challenger R/T
95 Heep Wrangler
90 5.Slow
99 HMC4 Sold
01 HMCO Sold
04 H2 Adv Sold
03 H2 Lux Totaled
HOPE Volunteer
