09-28-2007, 04:24 AM
blue bright light indicator light stays on
Has anyone had a problem with their blue bright light indicator light coming on after the vehicle has been turned off? I does it a lot after it rains. Thanks.
09-28-2007, 05:40 AM
Re: blue bright light indicator light stays on
What the bright light indicator? Never heard of that problem
09-28-2007, 11:59 AM
high beams indicator?
09-28-2007, 01:15 PM
Show us a photo of where that indicator is.
2009 H2 Silver Ice LE
09-29-2007, 03:33 AM
It is the high beams indicator light. It has come on when the ignition is off ever since I had the Hummer tunned up at 50,000 miles at the dealership. It even comes on when I have the driver door open for a few minutes.
09-29-2007, 06:40 AM
I'd have the dealer check it out since it happened on their watch. Did it do it before you took it in? If not, they are responsible.
09-29-2007, 06:51 AM
It sounds like something got screwed up when they updated your computer.
10-03-2007, 01:43 PM
Did you replace the headlight bulbs by any chance? I've seen the wrong bulbs installed cause something similar.
10-15-2007, 02:26 AM
No. I have had the windshield replaced in the past. I wonder if moisture is getting through somewhere.
10-15-2007, 12:42 PM
Has someone rigged the DRLs to stay on at night with the headlights?
10-15-2007, 02:24 PM
none of our mechanics have seen the problem...their suggestion is loose/pinched ground somewhere....
03-13-2009, 07:20 PM
I have the blue bright light indicator come on after the 03 H2 has been turned off for 60-90 seconds. When the indicator light comes on if I do any of the following all of the door locks will lock.
1.Open any of the doors
2.Flash High Beams
3.Turn on any inside lights
When I to get gas I typically would leave the key in the ignition, get out to fuel the truck, open the back door and all the doors lock. When I close the door I am locked out of the truck.
Any ideas on how I can fix the problem?
03-14-2009, 07:53 PM
take your key out of the ignition when filling up...
Jacksonville, FL
03-15-2009, 03:52 PM
 Sounds Easy enough!!
