Old 04-06-2009, 08:12 PM
pilot pilot is offline
pilot is on a distinguished road
Default wipers stop working on H2
My wipers arent working. I was wondering what the problem would be. I couldnt locate the fuse (saying front wiper), but I checked all the fuses in the fuse box and all seem to be good.
I am assuming the problem to be the switch or the motor. Where (Left or right side)is the motor located and how difficult is it to change one?
The H2 is 2005. I called the Hummer and they said there is no recalls on it.
Could some one tell me where the fuse is for the front wipers? Is it in the fuse box located under the hood on the left side?
Thanks for the help.
Old 04-06-2009, 08:40 PM
Easy Ed Easy Ed is offline
Default Re: wipers stop working on H2
What year of truck ? There was a recall on 13,358 trucks of the 2003 model year.
Here is a couple post on the wipers and how I fixed mine and have not has a problem since.
http://www.elcovaforums.com/forums/s...ad.php?t=29583
http://www.elcovaforums.com/forums/s...ad.php?t=35772
Edit: See ya made a edit, nope, no recall for the 2005 wipers.
You should have mail with some pics from the 2003 service manual that will help answer some of your questions.
Good luck, Ed
Old 04-07-2009, 01:50 AM
splne1's Avatar
splne1 splne1 is offline
My rear one seems to go out occasionally!!! Then it mysteriously works again???
Old 04-07-2009, 04:16 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
WS WPR fuse in the left ip fuse panel. 25a mini fuse. Wiper motor is just left of the center under the cowl
1998 Chev Z71
2007 Chev Trailblazer SS
Old 04-17-2009, 08:08 PM
notright notright is offline
notright is on a distinguished road
I had a similar problem with my '05. My front wipers wouldn't stop, my rear wiper and washers wouldn't stop, shortly after it had rained. I removed my airdam over the wiper motor, took the cover off (to expose s few corroded points on circuit board from water infiltration) , Black RTV'd the perimeter, and haven't had a problem since. Take off the round cover with clips on hte edge to expose the board. Seems like the same problems in 03's but Hummer won't cover.
