Old 03-11-2010, 06:41 PM
EuroHummer's Avatar
EuroHummer EuroHummer is offline
EuroHummer is on a distinguished road
Default Air Suspension has to go...
My air suspension on my 03 H2 has to go....the right rear is always lower and i have replaced two airbags in the last year. Does anyone know a good kit or parts to replace them with coils and airbags...I have a 6 inch fabtech lift, so it needs to sit as high as possible in the back.
2003 H2, 408 CI, K1 Forged 4" stroke crank, K1 6.125" forged rods, Wiseco X-Series 0.30 forged pistons, Schneider cam, FAST 102mm LSXRT, precision flow injectors, Comp Pro Magnum rockers, SA Gear DR timing set, ARP main studs, 90mm ETC TB, Airaid MIT, MSD Coils/wires, Dynatech Headers/high flow cats, Magnaflow, Jessie James Black Widows 20x9, Nitto Dune Grapplers 37", Fabtech 6" lift, CK Performance XHD 4l70e and 4.56 Gears
Old 03-12-2010, 11:26 PM
pdsq99f4 pdsq99f4 is offline
Default Re: Air Suspension has to go...
Fabtech has their own springs that are longer and lift the vehicle up. You just have to take off the spacers and put in an insulator on the bottom spring perch.
