Old 06-09-2009, 04:41 PM
GSHOCK's Avatar
GSHOCK GSHOCK is offline
GSHOCK is on a distinguished road
Angry Front diff /front end noise!!!
Snapping, slapping, popping noise coming from front end / diff of my 2005 H2 w/ 37k miles when turning left out of parking spaces / driveways. Initially thought it was coming from suspension, but after a trip to local suspension shop they said it was coming from diff. Had fluids changed recently and thought maybe a non synthetic oil was used, so drained diff and put in Royal Purple and even added GM limited slip additive for extra lube. Noise still there! It sounds almost like plastic snapping! Maybe new half shaft needed, diff gears slipping! I'm not sure where to start, but I don't want to start tearing my truck apart w/o some sort of direction! Any ideas?!?
Old 06-10-2009, 02:58 AM
lvmyhmr lvmyhmr is offline
lvmyhmr is off the scale
Default Re: Front diff /front end noise!!!
I had a similar noise on my 2004 at about the same milage. Dealer said it was the front body mounts. Do some searching there are posts about how to do it yourself. Hope this helps.
Gary
Old 06-10-2009, 02:30 PM
HumminNBoatin''s Avatar
That sounds like a 1/2 shaft to me. Especially if the problem occours when turning the wheels.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 06-10-2009, 07:47 PM
IRA51's Avatar
IRA51 IRA51 is offline
sounds like a CVC problem ,check and see if the boots are ripped. if they are bad change both shafts ,the other won't be far behind .
A government big enough to
you have.
-- Thomas Jefferson
Old 06-12-2009, 03:51 AM
GSHOCK's Avatar
Boots are in good shape! Probably going to start w/ 1/2 shaft! Thx for the input!
2005 H2 LUX Slate Blue w/ Blk lthr.
2001 HD Lowrider Custom.
Old 06-13-2009, 12:34 AM
IRA51's Avatar
grab them and shake them ,see if they move around .
you have.
-- Thomas Jefferson
Old 06-21-2009, 05:14 AM
I don't know if you've already checked the undercarriage protection. Take off the skid plate and the ucp, then drive it and see if it still does it. Sometimes the skid plate or ucp loosens up and causes a clunk noise when turning tight one way.
