Old 08-21-2004, 09:06 PM
Tom S Tom  S is offline
Tom  S is off the scale
This was taken off of Humvee.net I just thought some of you might be interested.
Well, I had a good talk today with the folks at one of the top diesel shops
in Salt Lake City and they told me that someone had brought in an H2 -- with a Duramax for work.
They said, yes, they know that supposedly it is not supposed to fit nor the
transmission -- but despite what the factory, GM, and everybody else has
said, they do fit and that they've seen it.
Apparently, the owner of the H2 purchased a Duramax truck and then removed
the engine and transmission from it and dropped it into their H2. The work
was done by a regular (gas) shop in Layton Utah.
These folks are incredibly knowledgeable and if they say it, I am very
inclined to believe it. They are magicians when it comes to diesels and
can do most anything if it can be done.
So, there you have it -- the Duramax can indeed fit in the H2. Perhaps
with not a lot of extra room (both of us wondered about cooling), but it
appears as if it can be done.
-Art
2000 Ford F-250 Diesel
1997 Ford Exploder
1999 Suzuki RM250 completely gone threw by Pro-action.
-Art
1997 Ford Exploder
-Art
1997 Ford Exploder
Old 08-22-2004, 12:32 AM
Livin\' Large Livin\' Large is offline
Livin\' Large is off the scale
Ya right. Show me pictures, receipts or something to verify this. I say not possible. The frame of the H2 will not accomodate the Duramax and Allison transmission. There is not enough room. I say BS....Till you prove otherwise....
Old 08-22-2004, 01:43 AM
As I said Livin i copy and pasted this for the humvee.net forum. Therefore i have no evidence. I thought it might be interests some people.
Thomas S
1997 Ford Exploder
Old 08-22-2004, 02:38 AM
Since I am very wise to most of the shops in SLC and am somewhat familiar withthe Layton area. I would like to find out what shop did this. I doubt it! But I guess anything's possible... with proof!
Old 08-22-2004, 02:57 AM
HUMMERDOGG HUMMERDOGG is offline
HUMMERDOGG is an unknown quantity at this point
Actually, go to:
http://www.real4wd.com/content/page-events.asp
Kascar is unveiling their supercharged diesel H2 on Saturday, September 25. They don't say if they used the Duramax or not, however it should be interesting...
-HUMMERDOGG
Old 08-22-2004, 10:31 AM
DURAMAX TIM is off the scale
Well since it's supercharged maybe they put a detroit in it.
98 ZR-2 Blazer
Ex H2&3 owner
Old 08-22-2004, 11:42 AM
mmayo mmayo is offline
mmayo is off the scale
Tom S is correct. Wait for the SEMA show in November.
Old 08-22-2004, 01:11 PM
Yetti Yetti is offline
My friend has a 3500 crew cab with a 471 Detroit & Allison trans. but it doesn't make it right?
I would prefer putting a cummins and a 6 speed in one over the duraturd.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 08-22-2004, 01:13 PM
alecs wife alecs wife is offline
alecs wife is off the scale
http://www.amgeneral.com/vehicles_gep_productinfo.php
I think this is the motor Kaskar is using in the conversion H2.
A super-charged OPTIMIZER 6500 is the perfect answer for those who demand the ultimate in power. This top-performing diesel engine provides better fuel economy than most “big block” gasoline V8s, while producing more than 300 hp at 3500 rpm.
Check it out.
CONFIDENTIALITY NOTICE: This post and any pictures posted with it are the property of Adam in CO and/or his affiliates. The contents of this post are confidential and may contain information that is privileged and/or exempt from disclosure under all
Old 08-23-2004, 05:14 AM
Steve R Steve R is offline
Steve R is off the scale
Hmmmm....for $20 I can get you a looping CD of diesel-sounds you can play really loud on your radio and for an additional $10 I'll throw in a "diesel fuel only" sticker for your fuel cap!
And if you act now we'll include a set of fragrance scents which will fill your cab with the scent of buring diesel fuel. Refills available!
Other accessories include a CD of assorted mechanical failure sounds; you'll get "snapped tie-rod (courtesy of some video circulating world-wide), burning tire rubber for lack of traction, "pop goes the diff", "clunk goes the under-frame" and my favorite "blam goes the skid-plate".
Old 08-23-2004, 01:23 PM
Hey Seth, the full LPE package is $55,000.
700 Horsepower @ 5,200 RPM
740 lbs – ft of torque @ 4,600 RPM
All wheel drive or 4 wheel drive
Complete 427 CID engine and turbo package includes:
Two true ball bearing turbochargers
High efficiency air to air chargecooler
4 into 1 custom stainless exhaust manifolds
Two K&N 360 degree conical air filters
Turbocharger water feed and return hoses
Turbocharger oil feed and return hoses
Custom 7.0 L aluminum C5R block
CNC porting and polishing of LS1 cylinder heads
Billet steel connecting rods
Forged 4340 crankshaft
Forged aluminum pistons
Custom hydraulic roller camshaft
High performance valve springs
Stainless steel one piece heavy duty intake 2.02” 1.60”/ inconel exhaust valves
Three angle valve job, checking of spring tensions & heights
Computer balanced rotating assembly
Reassembly and blueprinting of engine
Properly sized fuel injectors and high capacity fuel system
Professional installation, testing and PCM recalibration
LPE's 2 year / 24,000 mile warranty
Original engine long block in exchange
Engine package installed $55,975.00
http://www.lingenfelter.com/performance427suvturbo.asp
But of course this requires and engine swap as well.
Old 08-23-2004, 02:31 PM
I'd kill myself with that much power, plus it would just be too money buying tires all of the time.
I would like to see the diesel in the H2 as an option but would not want to give it a shot as a retro-fit.
The answer to your question as to why...because they can...why else? It certainly can't be any practical reasons.
Old 08-23-2004, 03:47 PM
Seth,
Diesel gas typically costs less per gallon then gasoline. Long ago it cost a lot less...today it's about the same, sometimes higher, but usually about 10 - 15% lower. So it's cheaper to buy by the gallon.
The big plus is the mpg: diesel often gets nearly twice the miles per gallon...well almost, depends on the application. My company runs some large trucks, the gas models (with big V8's) got about 7-8 mpg, whereas our International intercooled turbo-diesels enjoy nearly 14 mpg!!! BUT these are large trucks with heavy weight. Diesel engines do great with producing lots of torque to pull heavy loads, so they are ideal for heavy vehicles.
The other benefit is longevity: the same International trucks have a rating such that 90% of the engines are expected to run 480,000 miles before needing an overhaul. The gasoline engine may only run about 200,000.
So there you BASICALLY have it; fuel economy & longevity. The downside is the higher costs to aquire, difficulty in finding the fuel readily available (not all stations have diesel) and when you do work on a diesel, it typically costs more then a gas engine.
The diesel has smooth low-end torque and that's nice for offroading slowly. It also sounds really powerful and some like the fragrance.
Course, when I smell diesel it always takes me back to the stern of a boat where a tuna, yellowtail or dorado are about to meet their demise...
Old 08-23-2004, 06:46 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Steve R:
Course, when I smell diesel it always takes me back to the stern of a boat where a tuna, yellowtail or dorado are about to meet their demise... <HR></BLOCKQUOTE>So, Steve, is that an invitation?
Old 08-23-2004, 10:23 PM
Kevin B Kevin B is offline
Kevin B is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Hmmmm....for $20 I can get you a looping CD of diesel-sounds you can play really loud on your radio and for an additional $10 I'll throw in a "diesel fuel only" sticker for your fuel cap!
Other accessories include a CD of assorted mechanical failure sounds; you'll get "snapped tie-rod (courtesy of some video circulating world-wide), burning tire rubber for lack of traction, "pop goes the diff", "clunk goes the under-frame" and my favorite "blam goes the skid-plate". <HR></BLOCKQUOTE>
ROTF .
