Old 08-29-2009, 03:49 AM
CONRAD II's Avatar
Default Engine problem
Over the last few days I have noticed that when I turn the engine off on my H2 it doesn't always immediately shut down. It only runs for a sec or so before shutting down after I turn off the key and it doesn't do it every time. Any suggestions.....?
66' VETTE STINGRAY
07' Z06
Old 09-08-2009, 08:25 PM
H2illBilly's Avatar
H2illBilly H2illBilly is offline
H2illBilly is on a distinguished road
Default Re: Engine problem
Does it "diesel" when you turn the ignition off? Or run like it's still getting fuel?
Old 09-09-2009, 02:28 PM
CONRAD II's Avatar
After I turn off the ignition the truck continues to run exactly as normal for approx 2 secs then shuts off. It happens about 1/3 of the time I **** the truck down.
66' VETTE STINGRAY
07' Z06
Old 09-09-2009, 04:52 PM
HummerMann's Avatar
Is it the original ignition switch on the column? Maybe it went bad - as we all know pretty common.
Hummer, like nothing else
Old 09-09-2009, 05:51 PM
CONRAD II's Avatar
Actually, it's the 2nd ignition switch that I've had. The first one went out in 2005. When it failed my truck would not shift properly and the key wouldn't release from the ignition if I remember correctly. Does anyone know if the replacement ignition switch could be causing the problem?
66' VETTE STINGRAY
07' Z06
Old 09-11-2009, 09:56 PM
pdsq99f4 pdsq99f4 is offline
I had an underhood fuse block cause the same concern. It was shorting on the ignition 1 relay.
