11-03-2014, 01:07 AM
One Man Brake Bleeder
Any of you guys use a one man brake bleeder? I've bought cheap ones in the past that flat out didn't work. I'd like to get something that works and works well! I need to change out my brake fluid, stuff looks like Coke.
I had also through about speed bleeders so if anyone has used those I'd be curious how those work out as well.
Thanks in advance!
11-03-2014, 03:01 AM
Moderator
Re: One Man Brake Bleeder
LJ,
Lots of people on the Vette forum say A+ to the speed bleeders. (and trust me are these guys anal)
So I would go for it.
Are you doing a fluid drain and replacement?
If not, then you dont need to bleed... let me know and I can give you the 411
If so, then yeah speed bleed or there is one that uses what looks to be a plastic sprayer or vacuum jug too
'03 H2 (name: Big Gulp)
11-03-2014, 04:25 PM
When i replaced all my brake hoses with Crown Performance stainless steel brake lines, i used this to bleed the brakes. Easy to use and one man job. If you have a tech 2, you can also do an automatic bleed for the abs accumulator.
http://www.amazon.com/Mityvac-MV6835...=brake+bleeder
2008 Hummer H2 Luxury Edition
Toyo MT 38x13.50x18 on Rockstar. Green keys. 2" rear spacers. 1" bodylift. Cognito UCA, steering bracket, front stab links. Bilstein 5100 shocks & steering stab. Moog inner/outer TR, pitman, idler arm & bracket with remote zerk. E&G Classics fender flares. ARP 434-1301 ex. man. stud kit. Airaid perf. air filter. Crown brake lines. Warn PowerPlant HD. Rubberduck UCP. Gobi Ranger roof rack. DDM Tuning 55W HID Hi/Lo headlights. Hella fogs. Evans waterless coolant.
11-03-2014, 04:28 PM
I've looked at those Mityvacs.
I don't need to technically bleed the system of air, I want to replace the fluid because it is extremely black.
11-06-2014, 04:46 PM
I thought about buying Russell Speed Bleeders and some tubing to make it a one man job instead of using pressure/vacuum kits. Then I read the H2's already have one way bleeder screws...can anyone confirm this? I don't want to blow the money on the speed bleeders if we already have them!
11-20-2014, 04:48 AM
When I did mine I used a one man system. It was nothing fancy. I sucked out the old fluid from the reservoir, put new in. Then drained each line until fresh fluid came out. I don't recall the name of the tool, just remember it was easy, one man, and did the job.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Hybrid Mode
