Old 10-29-2009, 01:43 PM
st kitts st kitts is offline
st kitts is on a distinguished road
Default no heat passenger side
I have just taken my 04 H2 out of storage for my winter ride. I set both controls to heat and heat comes out the drivers side but cold comes out the passenger side. Is there a gate stuck?
Old 10-29-2009, 03:45 PM
Easy Ed Easy Ed is offline
Default Re: no heat passenger side
Gotta ask to be sure but, you do have the same heat settings for both sides, right ?
Ed
Old 10-29-2009, 03:47 PM
Yes, both set to high (hot). I even tried to set drivers to cold and passenger to hot but both came out cold.
Old 10-29-2009, 05:16 PM
Guess I missed that in your first post, about the heat setting that is.
Might need to have it checked for codes for starters. The manual has a list of DTC's for the HVAC system and there is a code for that door not opening/working.
Could try to disconnect the battery for a bit to see if it clears it up, just a suggestion/stab in the dark.
