05-16-2010, 10:06 PM
Advice for PIAA 510's
I'm looking to replace my DRL's with PIAA 510's. Just curious as to which bulb/pattern everyone suggests. Please, keep in mind that my truck is lifted...if you think that makes a difference. I'm concerned that the fogs will not get enough light to the ground.
Also, has anyone tried the 510 SMR's?
Thank you so much for your help.
Charles
05-17-2010, 02:27 AM
Re: Advice for PIAA 510's
+1 as well
Michael
___________________
2005 White H2 lux
2005 Dodge 1500 Hemi Crew Cab
2007 Tahoe (Flex Fuel)
05-20-2010, 06:04 AM
No one?
05-20-2010, 11:27 PM
I have the atp 510's in the drl location and worked great until i install my hid's. once i installed the hids, it washed out the 510's. my brother had the smr 510's and they were more like a spot. we compared them side by side and the atp had a better light pattern. hope this helps.
scott j.
2008 h2 sut
2008 escalade
1969 charger
05-21-2010, 02:51 AM
Thank you so much for your help. One question: What does "atp" stand for?
Charles
05-21-2010, 04:16 AM
atp=all terrain pattern...piaa combines a driving and fog pattern. it has the distance of a driving a width as a fog.
scott j.
2008 h2 sut
2008 escalade
1969 charger
05-21-2010, 03:39 PM
Thank you again.
Charles
