Old 08-27-2010, 04:22 PM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
Default Two Questions About SUT Bed
1. How does the plastic floor of an SUT bed come off?
2. How do you clean the trays that catch debris in the drains of the bed?
Thanks,
Charles
Old 08-27-2010, 04:51 PM
guruerror's Avatar
Default Re: Two Questions About SUT Bed
This probably won't answer your question...but may lend some insight.
CNTRY
DTOM
Old 08-27-2010, 04:54 PM
charles06's Avatar
Thanks. I'll have to study that. Haha
And to those of you looking at this picture, I need to get part #35 out.
Old 08-27-2010, 05:01 PM
guruerror's Avatar
I think you're on the right track...to get to 35 I bet you have to take 30 (and possibly 31) out; otherwise they'd show it on the diagram like 29 (above 30).
Good luck.
CNTRY
DTOM
Old 08-27-2010, 05:04 PM
charles06's Avatar
That's kind of what I figured. I'm thinking that the bolts for the tie downs are what hold the plastic in place.
Old 08-29-2010, 07:18 AM
Crush'em's Avatar
Crush'em Crush'em is offline
Crush'em is on a distinguished road
If you just need to clean them out, take a flat blade screwdriver and remove the covers (#29 in blow up). They are each held in by 4 tension prongs. Just pop 'em out. Then take your screwdriver and a pair of needlenose pliers to dig out the hard to remove stuff. Finish with a blast of water...
You can also just clean them out from below the truck with your finger, but they are easier from the top.
2007 Hummer H2 Yellow SUV
37"x13.5"x20" Toyo Open Country MT's, 20x10 Method Racing 301's, Fox 2.0 Performance Series Shocks, Truxx Level kit, color matched grill, (Almost) all chrome removed, Removeable U-steps, Factory All weather mats, Gobi flip-up front plate, Factory brush guard
Old 08-30-2010, 03:42 AM
charles06's Avatar
I got the trays out and cleaned them.
The reason I was asking about the "floor" was because I noticed there's a small gap where acorns and such could get under it, and I wanted to take it off and clean it.
