Old 06-04-2010, 02:36 PM
H2005's Avatar
H2005 H2005 is offline
H2005 is an unknown quantity at this point
Default electrochromic mirrors not working
My electrochromic mirrors are not working The drivers side is stuck in dimming mode and the rear view wont change at night. Any ideas?
Old 06-07-2010, 03:57 AM
H2005's Avatar
Default Re: electrochromic mirrors not working
Is there a fuse for it and I just cant find one?
Old 06-08-2010, 02:19 AM
Intercooled's Avatar
Intercooled is off the scale
If your an 05 or earlier ther were problems with the side mirrors. There is a TSB on it. Dealers changed out mirrors for the 06 model mirrors. the rear view I'm not sure about.
2006 H2 SUT Fusion Orange LE
Old 07-31-2010, 06:07 PM
H2005's Avatar
This is really a problem at night. anyone know what fuse it might be?
Old 08-01-2010, 12:26 AM
Easy Ed Easy Ed is offline
Out of 2003 owners manual.
Electrochromic Mirror Operation
The electrochromic (self-dimming) mirror function is
turned on automatically each time the ignition is started.
To operate the electrochromic mirror do the following:
1. Make sure the green indicator light, located to the
left of the COMP button, is lit. If it’s not, press and
hold the TEMP button for six seconds until the
green light comes on, indicating that the mirror is
in electrochromic (self-dimming) mode.
2. Turn off the electrochromic mirror function by
pressing and holding the TEMP button for six
seconds until the green indicator light turns off.
Old 08-01-2010, 12:40 AM
Out of 2003 service manual.
Old 08-01-2010, 03:24 AM
H2005's Avatar
Sounds like the short to voltage permanent damage. The inside mirror and the drivers mirror both do not work.
Thanks for your help
Old 09-28-2010, 01:58 PM
H2005's Avatar
Had my mechanic check it out yesterday the power us all there. I will have to take it to a Hummer dealer to have them hook it up to a tech 2 scanner to see if its the module or to see if I need a new mirror.
