09-16-2010, 01:48 AM
Wet floor, 06 h2 sut
Getting water on the floor on the driver side when it rains, any ideas how its getting in.
09-16-2010, 06:11 AM
Re: Wet floor, 06 h2 sut
Hmm... door seal, or maybe even somehow one of the amber clearance lights on the top. I would say window on most other cars, but the H2 has a recessed window, so very unlikely. Feel your headliner next time you see water to see if there is dampness.
09-16-2010, 09:47 AM
Let me see, I just got my truck back from the shop for the same issue and after the windshield was replaced seals were leaking at the A & B pillars and were taken apart to fix that, headliner removed to check sunroof & drains checked, cab marker lights sealed, wiring looms in the door sealed, door hinges taken off and sealed. I now have a dry truck but have a empty bank account. hope that helps.
09-16-2010, 11:57 AM
My money's on it being your door seal...make sure it's firmly pushed in place all the way around.
CNTRY
DTOM
09-16-2010, 12:13 PM
Ist place to look is driver side marker light. Remove light and underneath is a rubber grommet for the wires to pass down through the column. The grommet pops out of the hole. Clean well and use adhesive RTV sealant to hold grommet in place. Always the first place to look since vibrations from opening and closing driver door causes grommet to pop loose
2004 Black H2
09-24-2010, 02:33 AM
Thanks for the info. I will check each suggestion starting with the eazyest first and see how it turns out, I hope it's just the door seal.
09-24-2010, 10:28 PM
My spider senses point to the cablight!!! LOL Its been posted before.
09-25-2010, 01:16 AM
Lol, Spidy senses, I agree, just search the site for a ton of posts on this subject, cab lights will most likely be the issue.
2003 Black H2:
2006 Blue H2:
