Old 06-16-2008, 04:10 AM
DrG DrG is offline
DrG is off the scale
Question Replacing front CV Half Shaft Assembly
Has anyone every replaced a front CV Half Shaft Assembly? I poked a hole in one of the boots when I broke a tierod and a entire half shaft from RockAuto is as cheap as a new boot from GM. It looks easy enough but is it??
Also, what service manual describes this kind of stuff best? The factory manual??
David
2005 H2 Adventure, Nav, Sunroof
Old 06-17-2008, 03:30 PM
RuggedH2's Avatar
RuggedH2 RuggedH2 is offline
Default Re: Replacing front CV Half Shaft Assembly
I carry a spare in my rig when I wheel. I haven't had to use it yet, but I downloaded the directions for install and it is easy. It could be done on the trail with the right tools....... you will need a 35 mm socket and a breaker bar.
Old 06-17-2008, 10:37 PM
DrG DrG is offline
The procedure looks to be pretty straight forward. My regular mechanic had priced the labor at $200 and the axle at $150. That much of a labor charge made me think the axle was pressed into the wheel and was going to require a lot of work. After checking it out, I just don't see it being that tough unless the spline hangs up in the wheel. I picked up a new half shaft with a lifetime guarantee at O'Reillys for $60 plus a core charge that I'll get back. I think I have over-thought this one and made it more difficult than it's really going to be. I'll let you know after I do it this Saturday.
Old 10-14-2010, 08:50 PM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
Hey guys, the stealership just told me that my axle seal on the front diff is leaking, and the "axle spacer" on the opposite side is broken (I have a 6 inch fabtech lift so the spacer isn't stock). How hard is it to change those seals and the spacer? Is it just a matter of taking some bolts out and pushing that end of the axle aside? Or will the whole front end need torn apart?
Old 10-14-2010, 09:05 PM
Hellz Hellz is offline
holy thread hijack!!!
let alone raising the dead..
Old 10-14-2010, 09:19 PM
PaHumBug's Avatar
Yeah sorry for the highjack but this was the closest thread I could find in searching for my problem and figured you guys would know. In the future should I just start a new thread?
Old 10-15-2010, 02:54 PM
Hummerguy32 Hummerguy32 is offline
Hummerguy32 is on a distinguished road
Ya Think
Old 10-15-2010, 03:00 PM
PaHumBug's Avatar
Sorry I'm new to forums. I've been on this one for years but don't always come here unless I have questions and usually just find my answers by searching. I will start a new thread. My bad.
