Old 12-28-2010, 04:11 PM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Just Ordered
I just ordered a set of 20X10 Rockstars and the SS M16 in 37X13.50. I sure hope they fit alright.
I just have the Truxx leveling kit.
Fingers crossed, if they dont my wife will kill me.
Old 12-29-2010, 12:05 PM
snmazer snmazer is offline
snmazer is on a distinguished road
Default Re: Just Ordered
That is the same set up I was looking at. If you can, please post some pics when you get them mounted.
Scott
Old 12-29-2010, 01:24 PM
SmokeyJoe's Avatar
Gladly will post some pics.
So what do you think will it work???
Old 12-30-2010, 01:04 AM
[__--MUD--__]'s Avatar
Do you know what offset the rims were? Rest is luck.
Everything short of a fullblown lift...37x13.5 fit my rig great- AS long as I was only going to go in a straight line. Even looked at cutting out the wheel well liner, and beating over the pinchweld there. The width is what got me. Ended up putting on 6" lift. I dont regret it, just didn't plan on blowing that much cash in that short of a time.
Old 12-30-2010, 01:08 AM
Hellz Hellz is offline
do you have the air ride suspension?
you might have to do some triming of the plastic...
otherwise it "should" fit
Old 12-30-2010, 07:57 AM
SmokeyJoe's Avatar
No air suspension. Do you mean trim some plastic on the fenderwell? If so does that allow water to get any where it should not? Is the plastic just for looks?
thanx
The post above yours was a bit confusing.
Are you saying they will not fit without a lift kit?
Old 12-30-2010, 04:24 PM
StockStar's Avatar
StockStar StockStar is offline
StockStar is on a distinguished road
thanx
Just my 2 cents, but with the proper -24 offset & the 20x10s you should be good to go at least in my opinion and my experience. Cant wait to see those M16s mounted on those rims. I flipped a coin and ended up with the Toyo MTs 37x1350-20 ]
Oh, how many inches are you getting out of the truxx leveling kit?
Old 12-30-2010, 04:37 PM
the H2 will fit a 37 inch tire stock. there might be some rubbing, that it seems to vary from vehicle to vehicle. 2 identical h2s with same tires, one will rub, one wont.
So if you have any kind of a lift, you will be fine.
as for trimming the plastic. im sure it is going to let water in some areas, but kinda late to be asking that now isnt??
you could do the heatergun method.
find the rubbing spots and heat it up till it is pliable and form it so it stops rubbing. the spots that rubbed for me was the back part, very bottom.
here is the area you will most likely rub.
as you can see, i didnt trim mine far enough, and well.. things worked itself out.
Old 01-06-2011, 04:29 PM
splne1's Avatar
splne1 splne1 is offline
It will clear with the Truxx lift there are many forum members here with the same setup. Use the search feature here on the forum and you will be able to find it. BTW post up them pics when you get them bolted on and welcome to the Rockstar clan!!
Old 01-06-2011, 05:12 PM
MARKCORE's Avatar
MARKCORE MARKCORE is offline
MARKCORE is on a distinguished road
Same wheel size and tire I'm going to run. Interested in seeing the outcome and pictures. What is the offset of the wheels too?
