Old 04-08-2005, 12:16 PM
BLOWNZO6 BLOWNZO6 is offline
BLOWNZO6 is off the scale
I need to get at the back of my radio.. any instructions on console disassembly online?
I am sure I can just start pulling stuff apart.. there always seems to be that ONE clip you did not see or cannot get off.. just looking to save myself some headache.
TIA
2004 Black Lux
TIA
2004 Black Lux
Old 04-08-2005, 03:03 PM
Battlebugs's Avatar
Battlebugs Battlebugs is offline
Battlebugs is off the scale
Find "Center Console"
03 Yellow Adventure
97 SS Camaro SLP Build # 2919
Old 04-08-2005, 08:48 PM
Hummertech is off the scale
Here we go.
Take off shifter handle
pop up shifter plate, held on by 3 retainers that will most likely fall down by the bottom
of shifter. Use a flat blade screwdriver and be gentle.
then take out your compartment in console (underneath console lid).
Now you will see 4 10mm head bolts beneath your
console compartment, and one 10mm head bolt to the right hand side of shifter. Take those out.
Now here are your hidden bolts,
2 7mm head bolts that attach the console to the radio. they go toward the front of truck. you can feel them with your fingers. In the center, and a little right of center. Then, slide your console back.
Now take out your 2 hex head bolts on your radio trim plate, the rest of that tri m plate is
held on by retainers. just pull back after the bolts are out. Then disconnect y our lighter and aux. power connectors.
You're there.
