04-29-2011, 06:16 PM
Drivers side headliner coming down
Has anyone else had this problem? The drivers side visor on my 05 H2 was falling down now the clip is out and it wont go back in. The headliner is falling on the drivers side now. How do you fix it?
04-29-2011, 10:31 PM
Re: Drivers side headliner coming down
Hi maybe this will help you see if the tabs on the side of your clip are broken
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
04-30-2011, 02:49 AM
Its on the outside of the visor the part that holds the visor into the headliner
04-30-2011, 03:23 AM
Oh then their is 3 screws that hold the sunvisor up, are the 3 screws their? if they are there the little nut sert must have came out of the steel under the headliner. You need to remove the driver side weather strip and the front window inside corner trim piece and handle and lower the headliner abit so you can see if the nut serts came out. Maybe post a picture of the headliner sunvisor so i can see what has happened. Hope this helps.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
04-30-2011, 03:36 AM
Hi maybe this help
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
05-08-2011, 09:01 PM
Anyone have an easy fix other than liquid nails. Would silicone hold it up?
05-18-2011, 02:16 PM
The ring that I need is only sold with the headliner. What about expanding Insulation foam
Would that work?
05-18-2011, 03:05 PM
I have used the foam to hold the headliner up in the back of My Hummer, I have a 17in drop down Monitor that pulls the clips out all the time quick shot of foam and its been holding for some time now.
05-19-2011, 02:03 PM
Do you recall what the name of the foam you used is called?
05-22-2011, 04:44 AM
