Old 02-08-2011, 02:56 AM
HUMMDAT's Avatar
HUMMDAT HUMMDAT is offline
HUMMDAT is on a distinguished road
Default Tire and wheel suggestions...
I have a 2005 H2 SUT. Yellow, Chromed out but its missing some nice wheels and tires. I like the stock ones but I want something a bit beefier. I like the KMC XD wheels and I like Toyo Open Country M/T wheels and the Nitto Grapplers.
How big can I go with the tires without having to lift it or sacrifice my steering?
Also, would 20' Inch wheels be adequate?
Old 02-08-2011, 04:13 AM
Hellz Hellz is offline
Default Re: Tire and wheel suggestions...
37 inch tires
12.5 width
wont need a lift. might have to crank the torsion bars some.
Old 02-08-2011, 05:15 AM
HUMMDAT's Avatar
I just found my next set of wheels... MOTO METAL 909 SKULL with Nitto Grapplers.
Absolutely bad ass.
Old 02-08-2011, 06:51 AM
with 4.53" back space, they will stick waayyyyy out. You will also need to stick with a 35" tire. 37's with that wheel spec will rub without a lift.
try to find a 9" wide wheel with 4.75 to 5" backspace and you can run a 37 12.50 MT tire and will fit with little to no rub..maybe a slight tbar crank needed.
Old 02-08-2011, 07:38 AM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
This.
Old 02-09-2011, 02:01 AM
HUMMDAT's Avatar
So whats the verdict? 35s with a crank on the bars?
Old 02-09-2011, 03:01 AM
HumminNBoatin''s Avatar
On stock rims you can run the toyo 37x13.5 m/t but will need to crank the tbars and change the front shocks.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 02-09-2011, 04:37 AM
charles06's Avatar
As I understand it, it's all in the backspacing of the wheel. I bought my truck used with the Fabtech 6" kit already installed. The guy had Toyo 37x13.50x22's on it and it rubbed. The wheels had too little backspacing.
