Old 12-05-2005, 05:44 AM
MIZZOU H2 MIZZOU H2 is offline
MIZZOU H2 is off the scale
Anyone have a set or know of any cheap???
Drop the zero, grab a hero
Old 12-06-2005, 05:01 PM
partsguy partsguy is offline
Sut Guards are a pain in the back side to keep attached to the body.
Would not even bother to put them on.
Old 12-06-2005, 07:40 PM
mstams
When I had my SUT, the taillamp guards would not stay attached. It was a real pain.
partsguy -- Do you know if there is a new design with holes/screws? I know the guards on the Pacific Blue limited editions have screws, but I thought I saw some the other day on a regular truck that had screws as well.
Old 12-06-2005, 07:45 PM
Mr. I - Man's Avatar
new design has screws
Old 12-06-2005, 07:50 PM
mstams
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mr. I - Man:
new design has screws </div></BLOCKQUOTE>
Are they self-tapping or is drilling required?
Old 12-06-2005, 08:01 PM
Drill........
Old 12-06-2005, 08:46 PM
VTSTOMPER is off the scale
no more 3M DST. Oh well - drill the buggers!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 12-06-2005, 09:15 PM
don't know maybe boogers.???
I believe they were drilled . The stealership did them.
Old 12-06-2005, 09:30 PM
yep!
Old 12-07-2005, 10:08 AM
The damn Sut's are shaped strange and put pressure on the DST side of the guard.
They pop off all the time.
Drill and screw
What a thing to say here,...........
Old 12-07-2005, 11:23 AM
TXSUT's Avatar
TXSUT TXSUT is offline
The guards I have use existing screws and require no drilling.
Old 12-07-2005, 11:37 AM
mstams
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TXSUT:
The guards I have use existing screws and require no drilling. </div></BLOCKQUOTE>
Are you talking about the existing screws on the interior of the tailgate? All of them have these. We're talking about the outside attachment that previously used double-sided tape.
Old 12-07-2005, 02:19 PM
TXSUT's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by mstams:
Are you talking about the existing screws on the interior of the tailgate? </div></BLOCKQUOTE>
Yes, my misunderstanding.
Old 12-07-2005, 05:10 PM
TXSUT,
Are your's factory? I assume they are...
Old 12-07-2005, 05:15 PM
TXSUT's Avatar
TXSUT,
Are your's factory? I assume they are... </div></BLOCKQUOTE>
No, they came from H2 Source (if I recall correctly).
Old 12-07-2005, 05:20 PM
ok, I was checking them out in your "GOBI pics" and liked the look of them. I remember them having more cross bars than the factory ones.
Old 12-07-2005, 06:28 PM
TXSUT's Avatar
Yeah, they have one more cross bar than the factory guards, which are more in line with the separations of the bulb chambers than these are.
Old 12-07-2005, 09:48 PM
GLBLWARMR's Avatar
I had the same problem with mine. They were going off about every two weeks. I cleaned the area with alcohol and sanded the portion where the double sided tape attached to the guard and then cleaned it with alcohol. I used the heavy duty 3M double sided tape and they have held for the last month and do not show any signs of coming lose.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
Old 12-08-2005, 05:58 PM
TXSUT's Avatar
Are you guys talking about the whole guard coming off, or just the doube-sided tape?
