Old 04-14-2011, 08:21 PM
Sombra's Avatar
Sombra Sombra is offline
Sombra is on a distinguished road
Default 12v Switched Power Source for Bluetooth system
Need to hook up BlueTooth. Had it hooked into a GMX550 Lock Pick that just didn't work correctly. Removed the Lock Pick but still want the bluetooth.
I will mostlikely use Power Source for Radio, anyone know which wire in the harness is the power.
2008 H2
400kts is Great, but HUMMER at 70 is better.
Old 04-15-2011, 08:49 PM
Biskxp's Avatar
Biskxp Biskxp is offline
Biskxp is on a distinguished road
Default Re: 12v Switched Power Source for Bluetooth system
Think these are the pin-outs for both
BTW on the small connector block - PIN A puts the radio into "Phone" and activates a mono audio input across pins L and M
Old 04-15-2011, 09:37 PM
twr's Avatar
twr twr is offline
Hi what brand of bluetooth are you using? I have gm bluetooth and a gmx 550 in my 2008 truck and it works great.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 05-05-2011, 10:23 PM
Sombra's Avatar
Well the problem with the GMX 550 is the reverse video was washed out. I left the factory camera and wiring alone. GMX 550 Video on the move and iPod interface worked fine.
Using Parrott 3000 Bluetooth.
Old 05-06-2011, 04:25 AM
rmutchler's Avatar
rmutchler rmutchler is offline
rmutchler is on a distinguished road
I installed the BlueFusion Bluetooth, which plugs right into the XM module, works perfectly and even streams audio from my iPhone via Bluetooth! Not a seller of this device, but am now a fan! Google it, install is simple.
Old 05-07-2011, 02:26 AM
Sombra's Avatar
I owe you one! BLUEFUSION. I will eat. $89 bucks I paid because Parrot sucked!
I'll be getting this in the morning.....
Man you saved me at least 1 hour and having to splice into wires etc.....
Old 05-07-2011, 04:13 AM
rmutchler's Avatar
Glad to help, there is an install video on YouTube if you search for bluefusion.
Like I said, it works great and the mic can be well hidden so everything looks stock...much better than the parrot unit in my opinion. Good luck!!!!
Old 05-11-2011, 07:42 PM
Sombra's Avatar
It just arrived @ House. Saw the Video. Can't wait to get it in.
Don't know why when I searched for Bluetooth I never saw it.
I guess because I was adding Bluetooth to the GMX550, and the Parrot works OK with it.
Anyway once again this Forum saves me time and $$$$.
I did hear that the Music playback is not all that great, I have no issues using the AUX input so don't really care.
I will say that US automakers were slow to get the built in bluetooth stuff. My H2 is a 2008 and should have had an OEM BT setup.
Old 05-13-2011, 01:05 AM
rmutchler's Avatar
I really have no complaints on the sound of the music...it's great. I did hear the iPhones were having some distortion, but that's avoided by turning the equalizer off in the iPhone settings...never had mine turned on, maybe that's why mine sounds fine. Good luckmon the install...hopefully it works as great for you!
Here's one thing, your Bluetooth is controlled by the top left preset in your XM channels display. Have to press the button to get to the blue fusion and again to ge it to go back to radio...no problem though...just took me a few minutes to figure out.
Old 05-13-2011, 01:22 AM
Sombra's Avatar
Ok got it @ 4:30 hooked up with a Pro Clip mount to hold iphone done @ 5:00. Put a pro clip in my wifes Volvo also during the 30 minutes Only took so long because my 4yo was helping. SOUNDS GREAT! BT audio clear as a bell. Falls into my top 5 add ons I've ever purchased! Best part no splicing, cutting, trim removal.....
Old 05-13-2011, 02:09 AM
rmutchler's Avatar
Old 05-13-2011, 01:40 PM
Sombra's Avatar
BTW the Bluetooth switches back to Radio/XM after the call in my model. I just got the Iphone4 so I suspect the EQ is not on, but I am suprised how well the Audio sounds via Bluetooth. Voice dial (I didn't even know the phone did that), Call announce, ability to scroll thru incomming/missed/outgoing. Best part is my 4yo can play games while it continues to stream audio.
