Old 05-17-2011, 02:12 AM
PaHumBug's Avatar
PaHumBug PaHumBug is offline
Default More wiper problems
I know all about the wiper module moisture problem, fixed on two H2's in the past, my current rig being one of them. First time I fixed it they were going sporadically, so I got the module and dried it and sealed it with RTV. Then just the other day I noticed that they would hesitate half way through a cycle every once in a while. I was on a road trip this weekend and it started to rain and they wouldn't turn on at all. Rear wiper works fine. I went back in after the module and it looked dry. I sprayed it down with contact cleaner and dried it out, resealed it with RTV, and they still won't work. I am VERY dumb when it comes to electrical issues. Do you think I should just get another module? Or have someone look at it to see if the gremlin is somewhere else?
Old 05-17-2011, 09:34 AM
SmokeyJoe's Avatar
SmokeyJoe SmokeyJoe is offline
SmokeyJoe is on a distinguished road
Default Re: More wiper problems
I took mine apart and saw a cracked circuit board run. I soldered a piece of 14GA wire across it.
Could be your problem as mine did the same thing - intermitent, then one day nothing, then intermitent.....
Cognito UCA - Leveling Kit - Kryptonit Tie Rods - Bilstein Shocks - Cognito Support Kit - 37X12.5 Cooper Tires - Pro Comp 8128- Mercury Balancers
Old 05-17-2011, 08:46 PM
PaHumBug's Avatar
The circuit board looked fine as far as I could tell.
To re-word my question, what are the chances my module is fine and the problem is elsewhere?
Old 05-19-2011, 01:25 PM
PaHumBug's Avatar
Well, after 3 days of not working at all, they worked fine last night on my way home from work. I guess this means it is my module???
Old 05-26-2011, 02:41 PM
PaHumBug's Avatar
I'm not getting a lot of answers here, does anyone know what my next move should be?
We had a good rain last night and they didn't work this morning. Should I just cave and get a new module?
