Old 09-14-2009, 02:08 AM
HMH2SUT HMH2SUT is offline
HMH2SUT is on a distinguished road
Default Hood Cable Fix $4.00, 20 Min!
I had another hood cable snap yesterday. I had this problem with my 03'. For those of you who don't know.. The rubber around the cable actually traps moisture and rots them quickly. If you have rubber around your cables still your better off removing it. i dont think the newer models have the rubber.
I have seen posts asking where to get new cables in the past, even some recently. So here is my $4.00 homedepot fix to all those who need it.
Materials needed : at least 24" of 1/8 galvanized wire cable
(2) 1/8" Ferrule & stop sets.
1. Remove broken cable or rusted cable from truck by removing pins top and bottom.
2. slide broken cable and stops out. If cable is just rusted first cut cable.
3. Slide new 1/8 cable thur one metal end as pictured.
4. Slide "stop" over cable end as pictured and crimp tightly. If you dont have good crimping plyers use a Hammer to Pinch the "stop" on tightly.
5. Slide other end of cable thru remaining metal end. Slide metal "stop" over cable. adjust end and stop to desired length and crimp tightly. Should be ruffly 10.25 inches long between "stops".
6. Trim excess cable from end of "stop". Now you are ready to reinstall into the truck.
The pics should explain...
Old 09-14-2009, 02:29 AM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
Default Re: Hood Cable Fix $4.00, 20 Min!
GREAT idea....... Looking at your pic, you may want to put a wire tie around that parking lamp wire loom to keep it away from the hinge. Looks like the hood hinge is clamping down on that and a short may not be too far away!!!!
Old 09-14-2009, 03:32 AM
lasvegash2's Avatar
lasvegash2 lasvegash2 is offline
lasvegash2 is on a distinguished road
what happens when it snaps, does your hood fall forward? btw good write up.
scott j.
2008 h2 sut
2008 escalade
1969 charger
Old 09-14-2009, 04:47 AM
Easy Ed Easy Ed is offline
In 2005 they replaced mine under warranty with a "revised" model. One broke and they replaced both figuring the other was going to do the same . The old one had a outer cover and when the hood was closed water would set in the "loop" the cable made and would rust it out un-seen till it popped opening the hood as stated before. The new ones I think are stainless (so I was told) and have lasted 53,000 miles and still look good. Part number appears to be 15146196 on the invoice.
Ed
Old 09-14-2009, 05:05 PM
luv2camp... i already have a short. Its the outside marker light. I Hate wiring! I have to fix that and reroute everything just been putting it off cuz I hate doing any electrical.
I have only had one at a time break, and as long as the other cable isn't rotten it is plenty strong enough to support the hood alone. I cant really say what would happen if both go, it will def move forward... maybe just some scratches or something might snap like the hinge...
Old 09-14-2009, 11:08 PM
H2illBilly's Avatar
H2illBilly H2illBilly is offline
H2illBilly is on a distinguished road
I did the same thing when I bought my H2, I didnt even bother checking prices just went straight to Tractor Supply. Good write up.
Old 09-14-2009, 11:26 PM
Onde you fix the wiring, just pull that extra wire loom through the clamp more to the left and place a wire tie on the left side of the clamp at the wire loom so the harness cannot slide over to the right again.
Old 12-30-2010, 12:58 AM
h2con h2con is offline
h2con is on a distinguished road
I just did my 03. One of them had broke and the other rusted but was still together. I put a tie down strap on the rusted one while I was working on them. I didn't want to take a chance on the rusted one failing and the hood falling foward. Thanks for the info!
Old 09-22-2011, 07:18 PM
accely's Avatar
accely accely is offline
accely is on a distinguished road
nice guide I'm going to use this when I fix mine this weekend.
FYI - when they are both broken, like my h2, the hood just rests against the front bumper/steel when you have it open. It doesn't seem like it's a major issue but for as cheap as this fix is, might as well get them back together! And it sure beats the 150$+ amount the mechanic was quoting for fixing them.
Yellow 04' H2
