Old 07-13-2011, 07:17 PM
jlit2442 jlit2442 is offline
jlit2442 is on a distinguished road
Question what is the largest tire i can use on stock frame?
i have an 07 sut and was wanting to get some larger rims and tires, right now it has the 17" 315/35 goodyears, my truck is stock with no lift or spacer and was needing to know what is the largest tire diameter i can go up to that will clear my suspenion and fenders? any info would be great.
Old 07-13-2011, 07:32 PM
Big.Z.hummin's Avatar
Big.Z.hummin Big.Z.hummin is offline
Big.Z.hummin is on a distinguished road
Default Re: what is the largest tire i can use on stock frame?
well it depends on what rims you are thinking of. stock rims with 37's will normally clear. i have 17" Xd addicts with 4.5 in of backspace i believe with 37x13.5x17 ss m16's and have no rub but i also have the truxxx level kit. If you go with anything over an 18 in rim id stick with 35" tires 37's will rub. but just get the GM green keys or a torsion lift and 37's should fit just fine. keep in mind though each rig is a bit different. some have rubbing others dont. just depends on the rig
Old 07-15-2011, 02:14 AM
IRA51's Avatar
IRA51 IRA51 is offline
OFF ROAD TIRES OR BLINGY WHEELS AND LOWPRO STREET TIRES ?
A government big enough to
you have.
-- Thomas Jefferson
Old 07-15-2011, 08:15 AM
Lucky1 Lucky1 is offline
Lucky1 is off the scale
Big Z do you have any pics of your rig posted on the forum ? I have 4.5 backspacing also and was just curious to see yours.
Pimpin 8 E Z but somebodys gotta do it .
Old 07-18-2011, 05:16 PM
http://www.elcovaforums.com/forums/s...ad.php?t=41392
could have just searched under threads started by me
Old 07-22-2011, 02:34 AM
devilsfan's Avatar
37s are fine - IF - you have a decent alignment done. If you get a rub, then it's the alignment, not your tires.
I would occassionally get a rub on an incline with a sharp turn, but it was never enough to damage anything.
Stacy
