Old 12-04-2011, 04:30 PM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
Default Anyone With 4L80E Trans?
I did a search on this, and found a bunch of people talking about it, but only one guy who did it, and didn't report back on how it turned out.
So, has anyone done this transmission swap and care to share their experience? I'm debating going to 40's and want a stronger trans.
Old 12-06-2011, 01:23 AM
slippy slippy is offline
slippy is on a distinguished road
Default Re: Anyone With 4L80E Trans?
I looked into it a while back. If you google around youll find a swap kit and it will include a sub frame. Just make sure you have a shop that will swap the tranny AND weld the sub frame. iIts easy to find a metal weld shop, or an auto shop, but finding one that does both may be tricky depending on your area (due to liability issues).
anyway, a week after i said i was intrested in it, my stock tranny cooler blew up. on short notice i opted for a rebuilt stock tranny with a limited warrenty at the stealership.
Old 12-06-2011, 04:26 AM
charles06's Avatar
Thanks for the help. I did a search earlier in the week and found what you're talking about, but I was just curious if anyone here had done one and how it panned out. How many miles have you put on your rebuilt tranny?
Old 12-06-2011, 03:02 PM
guruerror's Avatar
(subscribing)...as I'm interested in hearing what folks have to say on this.
I'd also be interested in the costs associated with the swap.
CNTRY
DTOM
Old 12-06-2011, 08:03 PM
Humdingah Humdingah is offline
Humdingah is an unknown quantity at this point
$310 for the required transmission crossmember...item #10H2 about half-way down.
http://www.transmissioncenter.net/4L...4L80E_Swap.htm
Old 12-06-2011, 08:44 PM
charles06's Avatar
That's the site I've been looking through. I was just looking for some real-world success stories. Seems like a lot of little things to get right. I might just get my stock tranny rebuilt.
However, my local dealer bought a beefed up trans (not sure what kind) from a company in Colorado that also makes trannies for Chip Foose. He needed one for a lady with a supercharged H2 that kept blowing stock trannies. Said it worked great, and she beat on it. I'll have to get the name of the place.
Old 12-07-2011, 09:39 PM
charles06's Avatar
So has anyone simply rebuilt their stock transmission to be a little stronger?
Old 12-07-2011, 11:52 PM
[__--MUD--__]'s Avatar
Your probably going to have some better luck at ls1tech.com on swapping out the tranny... Technically it shouldn't be any different than the same swap in a camaro/firebird.
