Old 01-31-2012, 01:09 AM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Default Regearing?
Alright guys I need to regear my '08 SUT from the stock 3.73's..what would my best option be? Keep in mind that mine is the new 6-speed. My 3.73's just aren't strong enough to push 38's with 20's. Help please!
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 01-31-2012, 01:16 PM
EuroHummer's Avatar
EuroHummer EuroHummer is offline
EuroHummer is on a distinguished road
Default Re: Regearing?
I went with 4.56s. I have 37s. With the 38s, you might want to go to 4.88s. Depends on how much you travel on the highway, and how much time offroad.
2003 H2, 408 CI, K1 Forged 4" stroke crank, K1 6.125" forged rods, Wiseco X-Series 0.30 forged pistons, Schneider cam, FAST 102mm LSXRT, precision flow injectors, Comp Pro Magnum rockers, SA Gear DR timing set, ARP main studs, 90mm ETC TB, Airaid MIT, MSD Coils/wires, Dynatech Headers/high flow cats, Magnaflow, Jessie James Black Widows 20x9, Nitto Dune Grapplers 37", Fabtech 6" lift, CK Performance XHD 4l70e and 4.56 Gears
Old 01-31-2012, 02:28 PM
tyler1bo's Avatar
Right now it's more highway than offroad..my truck is about 90% street 10% offroad
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 01-31-2012, 05:28 PM
guruerror's Avatar
Check out this 'gear calculator': http://www.4lo.com/calc/geartire.php
My 05 had 4.10s stock, when I move to 37s it started to drag ass, so punched my info in the 'calculator' to find out what gears would give me an effective ratio closest to stock.
The tire size change had reduced my effective ratio to 3.88 and the calculator indicated that 4.33s would put my effective ratio back up to the stock level. Since they don't make 4.33s I went to the next 'lowest,' 4.56s, and have been a happy camper every since.
CNTRY
DTOM
Old 01-31-2012, 07:03 PM
tyler1bo's Avatar
It's showing me at 4.05..do you think 4.10's would be enough?
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
I did 4.88's with 38" Toyos and it made a HUGE difference. That gearing works well with my new 40's as well.
Old 01-31-2012, 07:08 PM
tyler1bo's Avatar
Does yours have the 4-speed tranny or 6? Mine has stock 3.73s with a 6-speed. I punched my numbers in the gear calculator and it's saying I should move to 4.10s
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 01-31-2012, 07:27 PM
2010_5thgen's Avatar
2010_5thgen 2010_5thgen is offline
2010_5thgen is on a distinguished road
those 6 speed tranny's are crazy. i drove my buddies 08 yukon denali and that thing was just stifting like crazy. seemed like at cruising speed, it didnt know if it wanted to be in 5th or 6th.
regearing should help with MPG and the pickup right? ive noticed mines a bit sluggish off the bat and it stays in 2nd gear longer than it used to. is this normal with a lift and larger tires?
2012 Porsche Panamera 4
Old 01-31-2012, 07:42 PM
tyler1bo's Avatar
Yes it should help both MPG and pickup..surprisingly though my I reset my CPU after the lift and I'm currently getting 11.5 hwy/city driving, which is brilliant for me. I would like to regear though because my shifting is getting sh*tty and slow, feels like my tranny is slipping. I took it in the shop to see if my tranny was okay and I think it's just my gears not being strong enough..I slip from 1st to 2nd kinda..
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 01-31-2012, 08:11 PM
charles06's Avatar
I have the 4 speed.
I always wonder how accurate those MPG readings are after I've changed the gearing, tire size, and used a tuner.
Old 01-31-2012, 08:21 PM
tyler1bo's Avatar
I still think it's pretty close..course I'm not stompin on it either..just cruisin mostly besides hwy. I think at worst i'm getting 10
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 01-31-2012, 08:49 PM
charles06's Avatar
Yeah, I try not to get too caught up in it. I just tell myself I'm getting more than what shows. Haha
Old 01-31-2012, 09:04 PM
guruerror's Avatar
I've got the 4-speed...
If the calculator says 4.05-4.10 then the 4.10s would put the performance closer to what you were used to before the tire size change. But to really get things back in order you should also use a programmer to let the 'computer' know that you've change the tire size and gear ratio; that should get your shifting and whatnot straightened out.
CNTRY
DTOM
Old 01-31-2012, 09:56 PM
tyler1bo's Avatar
I have a programmer. I'm using a superchips flashpaq at the moment.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 01-31-2012, 10:23 PM
guruerror's Avatar
You should be good to go then...looks like the Flashpaq allows you to adjust tire size and gear ratio just like my Cortex.
With some 4.10s and a re-program you should get your pep back, your shift points and cruising speed will be closer to normal, your speed-o will read correctly, and you may even get a whole MPG out of it.
CNTRY
DTOM
Old 02-01-2012, 02:05 AM
tyler1bo's Avatar
Not a WHOLE MPG!!!! Yes it's either 4.10's or 4.56's..
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 02-01-2012, 09:47 AM
Bimmer9938's Avatar
How much did it improve your MPG?
Old 02-01-2012, 02:06 PM
so 4.10 or 4.56 are good for 38" tires? i think im going to start with a tune, but im gonna take mine to a shop that has a AWD dyno to do a custom tune.
Old 02-01-2012, 04:40 PM
tyler1bo's Avatar
A custom tune will probably be the best. You probably need to look at 4.56 to 4.88 gears. I believe you have stock 4.10s. I think I may go with 4.56 because I'm not sure 4.10s will be that much of a difference. Do any of y'all know a good place to find gears?
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
Old 02-01-2012, 05:30 PM
guruerror's Avatar
www.trailduty.com...more specificially: http://www.trailduty.com/index.php?c...0cd11dd8a5fc9b
CNTRY
DTOM
