Old 03-22-2012, 09:43 PM
ryaleon's Avatar
ryaleon ryaleon is offline
ryaleon is on a distinguished road
Default Anybody know what this is?
No clue, definitely not stock. The little white top cup I mean.
Old 03-22-2012, 10:05 PM
guruerror's Avatar
Default Re: Anybody know what this is?
Well, what's the red thing?
Did you get that from Starkey188? I could be wrong, but it looks like a genuine Starkey-built, SF-28 moon rock energy extractor.
http://www.elcovaforums.com/forums/s...ight=sf28+moon
CNTRY
DTOM
Old 03-22-2012, 11:11 PM
ryaleon's Avatar
No clue where it came from, was on H2 when I got it.
Old 03-22-2012, 11:23 PM
ryaleon's Avatar
not sure what the red tank is either.
Old 03-22-2012, 11:25 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
where are all the lines going? What is the red thing? Almost looks like a battery housing since it has terminals on it but them the canister device is also connected to the red box. The other hose looks like its going to the intake which means it could possibly be some sort of vaccum line-for what I'm not too sure without more info!
Old 03-22-2012, 11:56 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Some sort of fuel saving device maybe. Im guessing you would fill the red tank with something and likely a pump inside it which would be activated off the relay mounted to the side of the fuse box. That would fill the white container then drawn into the engine using vacuum from the intake. Best guess I could come up with...
1998 Chev Z71
2007 Chev Trailblazer SS
Old 03-23-2012, 12:17 AM
ryaleon's Avatar
Its weird. The red box indeed has terminals and leads to the fuse box. The hose leads to the white top cup which has another hose that leads to nothing. guessing it used to be plugged into something. the red box looks like a gas can haha.
Old 03-23-2012, 01:11 AM
[__--MUD--__]'s Avatar
thats a hydrogen generator!
Old 03-23-2012, 01:18 AM
ryaleon's Avatar
Maybe an early version of the Flux Capacitor.
Old 03-23-2012, 01:21 AM
guruerror's Avatar
Whats the little black thing on top the red box say? Looks like "BA..."
CNTRY
DTOM
Old 03-23-2012, 01:31 AM
ryaleon's Avatar
added some more pics of it.
Old 03-23-2012, 01:35 AM
crewj92 crewj92 is offline
crewj92 is on a distinguished road
I don`t know where you are located but was there a snowplow mounted on your H2 at some point?
Old 03-23-2012, 01:36 AM
guruerror's Avatar
Crazy! WTF?
CNTRY
DTOM
markdoddridge markdoddridge is offline
markdoddridge is on a distinguished road
I think its obviously a flux capacitor, got one on my 85 Delorean. Dont ever take that bad boy over 88 mph..... Trust me.
Old 03-23-2012, 01:38 AM
ryaleon's Avatar
guess im gonna have to go back to the future!
guruerror's Avatar
...or it's a still. It's got a cup holder after all...bet it makes some mean moonshine!
CNTRY
DTOM
Old 03-23-2012, 01:42 AM
ryaleon's Avatar
No snowplow as far as I know, I'm in West Texas.
Old 03-23-2012, 06:16 AM
that plug that says BANJ is just like a locking cap that is used on a pressurised tank. Thats where you fill up w/ the water solution.
That white cup is the back feed explosion protector- If for some reason combustion feed back into the line, that cup is supposed to prevent from feeding all the way back to the generator.
There has to be a power switch for the tank unless its wired direct to the ignition. There should be a bunch of plates that are directly shorted to extract the hydrogen in the tank. If its not switched and I'm right, if there isn't any water in that tank- Those plates are still heating up.
Doesn't look like the output is connected, there should be a fitting on the plastic area intake tube someplace for that to connect to.
Old 03-23-2012, 06:50 AM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
WTMF! Don't know what the hell that thing is, that is a little scary having something like that with cables and tubes sticking out of it going to who knows where...
Sounds like MUD is thinking that you got yourself a hybrid hummer man!
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 03-23-2012, 02:16 PM
guruerror's Avatar
MUD, I think you're right. I remember reading about these back when I was looking at the 'fuel energizers' and other MPG-increasing gimmicks.
If it is what MUD thinks it is, and it is connected directly to the battery with no ON/OFF, I would definitely remove it sooner rather than later.
CNTRY
DTOM
