Old 03-22-2012, 09:09 PM
SUT-UP SUT-UP is offline
SUT-UP is on a distinguished road
Default Bedliner on Chrome Gas Cap
I know someone(s) on here has sprayed their chrome gas cap with bedliner.
Any fitment issues??
Old 03-26-2012, 04:35 PM
Default Re: Bedliner on Chrome Gas Cap
Nothing huh? Ok I guess we are going to have to find out the old fashioned way.
Old 03-26-2012, 04:41 PM
guruerror's Avatar
Well...I sprayed my aftermarket cap with bedliner; and it fit the same...no issues. The spray-on bedliner isn't much thicker that spray paint, so you should be fine.
Line-X might be a different story...
Make sure you rough it up with some sand paper first...but you prolly already know that.
CNTRY
DTOM
Old 03-26-2012, 06:43 PM
I knew after all the black trucks on here someone must have taken the less expensive way to a black cover. Thank you much Guru.
Old 03-26-2012, 07:28 PM
Humvee21 Humvee21 is offline
Humvee21 is on a distinguished road
You could always try Plasti Dip
Old 03-26-2012, 07:29 PM
guruerror's Avatar
...but that crap peels off. Bedliner is forever!
...well, for quite a while.
CNTRY
DTOM
Old 03-26-2012, 08:37 PM
Yea. I am still not crazy about the PlastiDip. I wish deathshead67 would have posted a recent picture of the 5 month mark instead of the original sprayed picture of his grille on the other thread. I am going to stick with the bedliner.
Old 03-26-2012, 09:47 PM
I fully agree; however, Plasti Dip is so prominent in today's automotive modification industry that I think you'd be making a mistake not trying it out. People have been using this stuff on their wheels and it has been holding up well. Also, if you ever consider selling your vehicle you have the option of peeling it off to reveal the way it was from the factory (or at least before you sprayed it )
Old 03-26-2012, 09:53 PM
guruerror's Avatar
Sell? NEVER!
CNTRY
DTOM
Old 03-26-2012, 10:00 PM
Originally Posted by guruerror
Sell? NEVER!
I agree once again
But you never know what circumstances might come up. Anyways, if you heard they started up production again I bet many would trade up for a newer one.
Old 03-29-2012, 10:02 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Here is a quick pic of mine I sprayed with Plasti Dip the other night, washed the truck and got it back on earlier today. Turned out awesome, blows away the chrome look anyday!! I did have to spray around the edge of the lip where your finger goes to open the door to prevent any peeling. We'll see how it holds up, worst case I'll end up buying a black locking door but I'm farily confident in the Plasti-Dip.
Old 03-29-2012, 12:39 PM
guruerror's Avatar
Looks sharp! Just be careful not to get gas on it...that might start to break it down.
CNTRY
DTOM
Old 03-29-2012, 01:02 PM
Looks good. Hopefully it holds up for you.
Old 03-29-2012, 05:01 PM
Looks good! Did you plastdip the taillight guards as well?
Old 03-30-2012, 12:29 AM
LoJac963's Avatar
I will be babying it for sure, got gas for the first time today after spraying it and was very careful. The tail light guards I bought in black so they're just factory black. Thanks for the comments everyone!
Old 04-07-2012, 11:52 PM
Succombed to the plastidip. Mixed feelings. Sprayed the gascap and wifes gmc emblem. Gascap came out decent. Look i was going for definitely. Wifes emblem is whole different story. Sprayed on the truck just taped it off. Once sprayed had to slice each edge with a razor blade to get tape to peel away from emblem without peeling the coating. She wasn't a fan of how easily it lifted off. Ended up peeling it off. It came off in two minutes which i guess is the most positive thing out of the product. I really can't see a practical use for it other than as a temporary solution. The look is superb but the inevitable is that all the work to use the plastidip is going to either have to be done again or the correct prep work and painted will need to be done.
Overall i am giving the product a B-
Has a great temporary look and hopefully it lasts for a decent time in the gascap. Ease of use when taping is awful. More fine cutting time than prep and spray. Best of luck to anyone who goes this route. I will keep you updated on its appearance.
Old 04-08-2012, 11:13 PM
LoJac963's Avatar
I will agree with you, its ease of removal is also a downfall. When I reinstalled my fuel door the bottom allen bolt twisted the rubber and pulled it away from the bolt hole. I have to cut it away with a blade and respray the bottom of the door.....which I'm still having issues with so I as well have some mixed feelings. I may say the hell with it and order the GM locking black door.
Old 04-09-2012, 01:06 PM
I filled up for the first time today with it. No issues. I am not crazy about the texture on it. I think it is going to last me until the next sunny day and then get stripped, sanded, and bedlined. I should have went with the original plan, however I am glad that I did try it so I know to rule it out next time.
Old 04-09-2012, 04:11 PM
I apologize for misleading you to plastidip, then...
Old 04-09-2012, 04:14 PM
No worries. Could have turned out the other way. Got to live to learn.
