Old 04-17-2012, 05:44 AM
Bimmer9938's Avatar
Default Steering Wheel Rocking....
http://youtu.be/bm-EQTkHnzo
Well all of a sudden my steering wheel got loose, I bearly ever drive Big Black and he has low miles and I NEVER pull on the steering wheel to get into the vehicle either. It It does not rock forward and backwards at all now side to side... but if I push down on one side the opposite side lifts up and you can not only feel it, you can hear it as well. Anyone else have this problem? This is on a 2005 H2.
Old 04-17-2012, 05:54 PM
[__--MUD--__]'s Avatar
Default Re: Steering Wheel Rocking....
can't tell from the video. Does it feel like the wheel is loose on the shaft? or does it appear tight on the shaft and the entire shaft is wobbling in the column/tilt assembly?
Old 04-17-2012, 06:51 PM
Humdingah Humdingah is offline
Humdingah is an unknown quantity at this point
Bad or loose steering shafts are a common GM issue...you can get a heavier duty replacement shaft through Borgeson for like $200.
Old 04-17-2012, 07:07 PM
Bimmer9938's Avatar
It feels like the wheel is rocking on the shaft. I brought it to 4WPS, they said take it to a dealer cause the steering linkage all looked good. Is it possible the wheel just got loose on the shaft?
