Old 05-01-2012, 10:21 PM
ryaleon's Avatar
ryaleon ryaleon is offline
ryaleon is on a distinguished road
Default Knock sensor replacement
Anybody done this?
Old 05-02-2012, 12:12 AM
Easy Ed Easy Ed is offline
Default Re: Knock sensor replacement
Yup, here is a post on it, hope it helps.
http://www.elcovaforums.com/forums/s...ad.php?t=37498
Old 05-02-2012, 02:36 AM
HMH2SUT HMH2SUT is offline
HMH2SUT is on a distinguished road
I have replaced mine twice because i like playing in the local ponds. Its not a tuff job but can seem like alot of work when you think about their location. If you want I can give you some directions and pics let me know good luck.
2005 SUT Used and Abused, you name Ive broke it!
Old 05-02-2012, 09:12 PM
ryaleon's Avatar
Quite a bit to take off huh?
Old 05-02-2012, 11:28 PM
yeah there's a bit to take off but nothing to hard. They are located under the intake so it has to come off. If you are going to tackle this job make sure you buy a new wiring harness from the dealer and replace this at the same time. And just my advice don't buy the new knock sensors from a local chain parts store get the dealer replacements. I believe my harness was $40ish and the sensors $80-$90ish a piece. Also pick up a new intake manifold gasket. you maybe able to reuse yours without issue but trust me you wont wanna take it back apart to fix a leaky intake.
this is where the 2 sensors are located.
mine where filled with water both time i replaced them
Old 05-02-2012, 11:48 PM
ryaleon's Avatar
well ive managed to get it apart. pretty sure i know where everything else goes to put it back except one wire. in the middle of the intake. looks like a spark plug wire kind of.
ryaleon's Avatar
you got the part numbers for the harness and gasket? how do you release the harness on the senors?
Old 05-03-2012, 01:06 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Also remove the foam from the back of the intake this will allow water to exit out the back side and build a half moon dam with silicone on the front side of the knock sensor seals so water entering the intake valley from the front side will go around the dam and exit the back. This will keep water from pooling in the sensor holes
1998 Chev Z71
2007 Chev Trailblazer SS
Old 05-03-2012, 01:10 AM
HUMTECH's Avatar
to release the connector squeeze together on the wide side of the connector, i usually use needle nose pliers cause they can be tough.
1998 Chev Z71
Old 05-03-2012, 01:12 AM
ryaleon's Avatar
anybody know where that center connector goes?
Old 05-03-2012, 01:13 AM
HUMTECH's Avatar
Can you take a picture
1998 Chev Z71
Old 05-03-2012, 01:15 AM
ryaleon's Avatar
on its way
Old 05-03-2012, 01:19 AM
ryaleon's Avatar
Old 05-03-2012, 01:20 AM
HUMTECH's Avatar
PCV pipe, goes to left rear valve cover
1998 Chev Z71
Old 05-03-2012, 01:28 AM
HUMTECH's Avatar
Anymore questions before i log off?
1998 Chev Z71
Old 05-03-2012, 01:32 AM
HUMTECH's Avatar
Intake bolt torque is important so you dont end up with vacuum leaks, first tighten in sequence from the middle working out to 44 inch lbs. Then a second pass to 89 inch lbs. Then double check at 89 inch lbs
1998 Chev Z71
Old 05-03-2012, 01:33 AM
HUMTECH's Avatar
1998 Chev Z71
Old 05-03-2012, 10:43 PM
ryaleon's Avatar
Thank you all for the help. I believer Ive done it all correctly. so far so good.
