Old 06-16-2012, 04:29 AM
pdxrealtor's Avatar
Default 50k Service/Trans service
I'm at 50k.
This is what I've done or plan on doing. Am I missing anything or is anything overkill?
Tranny service.. I'm assuming I should have the system flushed by a shop... correct?
External Tranny oil cooler
Transfer case drain/refill
Front/Rear Diff drain/refill
Power steering flush -might just suck the old out and dump in some new.. opinions?
Cooling system flush
Air filter
Shocks
Steering stabilizer
Have shop inspect front steering components
I had an alignment at 27k. Do I really need another? Can tire be assessed to determine?
I'm doing my regular things... oil/filter, MAF cleaning/Tbody cleaning, lube front end, rotate tires.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 06-16-2012, 12:30 PM
HummerMann's Avatar
Default Re: 50k Service/Trans service
I had my 50k service done at a Hummer dealership several years ago. They recommended the GM anti-foaming additive for the transmission with the fluid change because I did some towing in those days. I flush and change my own radiator fluid every three years. My front end goes out of alignment often and the old lift kit I had on it before I went back to stock, so I have that done yearly. I also put new brake fluid in at 100k. I also had to replace the MAFs and O2 sensors at 92k to pass emission testing.
Hummer, like nothing else
Old 06-16-2012, 05:21 PM
tiny2012's Avatar
tiny2012 tiny2012 is offline
tiny2012 is on a distinguished road
if you search transmission service,theres alot of info already available.
Old 06-16-2012, 05:25 PM
pdxrealtor's Avatar
One would think,, Huh?
Not many results for transmission service or any variable.
Thanks Hummerman... for your info. I might end up having to go the dealership for my trans flush.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-16-2012, 06:16 PM
pdxrealtor's Avatar
Just bought the external trans oil cooler.
I'm thinking it would be best to install that before the trans flush. Anyone have a different opinion?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-18-2012, 03:56 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Definately switch to Dexron VI for the tranny & T-Case. It already has the newer anti-foaming spec, more shear stable, high temp stable, lower pour point, and the friction properties are MUCH better. My truck shifts like butter and the switch.
Old 06-18-2012, 03:58 AM
pdxrealtor's Avatar
Dex 4 for the transfer case??
I already stuck redline D4 (dex 3 equivalent) in the TC
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-24-2012, 09:13 PM
pdxrealtor's Avatar
Well I've got most of it complete. Put the new shocks on yesterday. Getting the tranny service and corvette servo done tomorrow.
I'm still waiting on the stabilizer bracket but a side from that it's done.
Really glad I did it myself. Saved a lot of money, know its done right, and know my truck a little bit more.
Damn I want some long tubes and exhaust. And some heads and a cam, larger injectors.....
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-26-2012, 03:21 AM
No you should have used Dex VI.
Old 06-26-2012, 03:26 AM
pdxrealtor's Avatar
The manual does not say dex 4, it says dex 3 or the like with an H specification.
Haven't done any reading about others using dex 4 in the TC. But I did read about a lot of people who put Redline D4 in the TC. Also read about a couple people going back to the GM approved fluid due to the 4 wheel light coming on briefly.
You're the first to say dex 4. Care to elaborate for us?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-28-2012, 03:10 AM
GM doesn't even license Dexron 3 anymore and was replaced by Dexron 6, a huge improvement over 3. 6 is backwards compatable with 3 and GM even put out a bulletin saying 6 should be used in place of 3. Not that the Redline D4 is bad, but the Redline D6 has a tighter viscosity limit and is more shear stable.
