Old 12-01-2012, 05:41 PM
jarek m's Avatar
jarek m jarek m is offline
jarek m is on a distinguished road
Default No start.
So the truck lasted problem free about two years after big rebuild, good run for a 200k truck with $2k refresh.
Air ride compressor is out again after 50k miles or so.
But the big problem is new no start and dead OBD2.
The truck just died on the go and wouldn't crank after. It has all the symptoms of a dead battery but its not it, I also bench tested the starter... Ok.
Recently I started getting low engine power and it would clear by turning the ignition off.
All fuses ok, starter relay tested ok.
Missing the times when things where made to last.
Old 12-01-2012, 07:56 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: No start.
Do you have a remote starter that is tapped into your data line right behing the data link connector? If so remove the splice and try that.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 12-01-2012, 09:32 PM
jarek m's Avatar
Not anymore, that's the first thing I took out, reconnected al the splices
Old 12-01-2012, 09:38 PM
jarek m's Avatar
Also today I astablished that starter cranks the engine when jumped, no start. Ignition relay clicks but starter relay don't, even when swapped.
Old 12-01-2012, 10:01 PM
HUMTECH's Avatar
Try using a jumper wire across pins 87 and 30 of the starter relay and see if starter cranks
1998 Chev Z71
Old 12-01-2012, 10:08 PM
HUMTECH's Avatar
1998 Chev Z71
Old 12-01-2012, 11:25 PM
Hellz Hellz is offline
is teh passlock icon lite on your dash?
Old 12-02-2012, 12:50 AM
jarek m's Avatar
It comes on and off once a week
Old 12-02-2012, 09:19 PM
jarek m's Avatar
The truck started crankin but no start.
Old 12-02-2012, 09:38 PM
jarek m's Avatar
10A crank fuse lights up when key in crank position...
Starter relay 87, 30 good 85 goes positive when key in second position, so I'm assuming that 86 should get grounded for cranking?
Old 12-02-2012, 09:49 PM
HUMTECH's Avatar
Check the other 2 pins of the start relay, one should have power in run position and the other should have ground in the crank position
1998 Chev Z71
Old 12-02-2012, 10:32 PM
HUMTECH's Avatar
If its not getting a ground during crank ecm is not sending crank signal.
1998 Chev Z71
Old 12-03-2012, 12:14 AM
jarek m's Avatar
Thats what it looks like. You wouldn't happen to have a decent ignition diagram?
Old 12-03-2012, 12:34 AM
jarek m's Avatar
No crank signal, no OBD conection and no spark or injection... ECU
Old 12-04-2012, 01:28 AM
HUMTECH's Avatar
As long as the data line is good, power and ground at ecm is good then ecm is bad.
1998 Chev Z71
Old 12-04-2012, 06:23 AM
jarek m's Avatar
That's where I'm heading, good to have second opinion, thanks.
Old 12-10-2012, 08:23 PM
jarek m's Avatar
All grounds tested ok and 2 pink tested 12v on the ECM plugs.
ECM looked ok in every way
Old 12-11-2012, 05:44 PM
jarek m's Avatar
New ECM in route...
Old 12-15-2012, 06:15 PM
jarek m's Avatar
New ECM still no start :/
Old 12-16-2012, 12:34 AM
HUMTECH's Avatar
Did the dealer program it for you
1998 Chev Z71
