Old 03-23-2013, 02:01 AM
H2Miami's Avatar
H2Miami H2Miami is offline
H2Miami is on a distinguished road
Default Need Help with rear wheel noise
HI every1
I was doing an inspection to the wheels and found the two rear wheels move when push up and down like when you checking for a bad bearing .... Both does the same ... No noise while riding but when I try to move it it makes like a bum-bum ....
Just trying to figure out if that is normal or there is something wrong ...
Any advise appreciate .... Thanks
Old 03-23-2013, 02:44 AM
iwillnc's Avatar
iwillnc iwillnc is offline
iwillnc is on a distinguished road
Default Re: Need Help with rear wheel noise
It's likely if both bearings in the rear axle are bad that the stress probably also bent the seals so you may be able to see some leakage from around the axle shafts.... maybe...
But that is kinda wierd, that's a big axle for that to happen to...
Old 03-23-2013, 03:18 AM
H2Miami's Avatar
iwillnc thanks for your response ....
I didnt see any leakage but I will double check tomorrow again ...
Weird the two bearing get bad ,,, also they both sound and move identically...
Ironically the two on the front are good , which should have been on more stress due to the engine weight
IN any way ... the movement and noise isnt normal right ?
Old 03-23-2013, 04:03 AM
H2Miami's Avatar
I was reading in this thread the same problem I have http://www.elcovaforums.com/forums/s...ad.php?t=42603
Well while some people says it is a normal thing . others say to replace bearing ;;;
Not a final verdict ... Who to believe
