Old 01-16-2014, 06:55 PM
jsbihn jsbihn is offline
Moderator
Default Lets Play "What is the PN"
Hey all,
Ok I am having issues finding a part number for a basic piece of my A/C.
I replaced everything last year but I have a leak it seems. I think the leak is in the shrader valve (back valve or fill valve), since I put dye in it and it appears to be very slow possibly from that valve. Given I am not 100%
Anyways, the issue is to replace the back side valve (I am not sure if it is the Hi or the Low, I always get them crossed when I am not in front of them) I need to be able to order the part..... but I cant find on Nally GMC's online parts book that part number that matches the diagram number.
If you refer to this picture:
http://parts.nalleygmc.com/images/pa...25TN09-003.JPG
I am trying to find the part number for #34.
Thanks for the help
'03 H2 (name: Big Gulp)
Old 01-16-2014, 08:12 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Lets Play "What is the PN"
I think this is what your looking for, double check it though 52458184
1998 Chev Z71
2007 Chev Trailblazer SS
Old 01-16-2014, 09:24 PM
Moderator
Thanks HT,
I pulled up the picture of the PN you provided on Nalley and the associated picture doesnt look exactly like #34 on the picture I provided. In fact it kind of looks like another system for a different vehicle.
Of course I could very well be wrong
Any ideas?
Is it the same part and will fit?
Am I seeing it wrong?
Old 01-17-2014, 01:23 AM
HUMTECH's Avatar
Had my parts guy at work look it up so im not 100% sure. Sometimes they use generic pictures. Try to just google the part number and see what ya come up with.
1998 Chev Z71
Old 01-17-2014, 02:29 AM
Easy Ed Easy Ed is offline
The part number does come up when Googled with pictures https://www.google.com/search?q=52458184&rls=com.microsoft:en-US:IE-SearchBox&tbm=isch&tbo=u&source=univ&sa=X&ei=34bYU s2pGsb4yAHPyYCgDQ&ved=0CDYQsAQ&biw=1366&bih=652 to compare, most likely used on may GM vehicles. It looks though in the pictures that you do not get the valve core item 24, (valve core looks the same as a tire valve stem valve core) so if you are leaking out the top the valve core could just need screwed in to seal, can get a valve core tool at a parts store. If you are leaking farther down on the fitting near the joint of the two mating parts it could be the sealing O-ring has gone south. O-rings are cheap and easy to get, hell I deal with them every day in our business.
Good luck, Ed
Edit: Ignore the above, it appears to not apply. It looks as though HUMTECH may have gave you the parts number to the front one (it appears to be replaceable) and you need the tube and fitting the is in the rear of the attached picture. Went out to the truck to look (damn the garage floor is cold) and took the picture. Now we need to find that part number for #34 like you requested. I will look around the web to see what I can find or maybe HUMTECH can see if he can get the part number.
Edit: No luck finding the part number, sorry.
Old 01-17-2014, 04:13 AM
HUMTECH's Avatar
You are correct sir, the closest one to the firewall in the picture(real pics help thanks) is the low side fitting. I did give the other one as the part number which is the high side fitting with a non serviceable core. Any auto ac shop should be able to get you the low side core to go into the fitting. Thanks for the correction Easy Ed
1998 Chev Z71
Old 01-17-2014, 12:58 PM
Moderator
You guys are awesome!
Thank you for the assist. True buddys of the forum.
So, if I get this straight.....
1) currently we are unable to find the part number for the part needed
2) it is the low side (the one closest to the cab wall)
3) there is a chance to have the valve internals replaced (since I think this is where it is leaking from..... I think the valve has lost its ability to spring back correctly and seal)
anything else we can think of?
Let me know
