Old 11-30-2014, 09:17 PM
jsbihn jsbihn is offline
Moderator
Default Buying Parts - whatcha Think???
Hey all,
I am curious if anyone has experiences with any of the following products.... or could possibly recommend something else.
I am not looking so much as for performance as for quality, BUT if you happen to know of a HiPo that would be better and for the same cash..... well.....
front hub/bearing assembly - Timkin
platinum spark plugs - Bosch O.E. Type
ignition wires - Taylor 8mm, B&B 8mm, Bosch 09017 Premium
rear springs (replacing the bags and compressor) - OEM Springs, Touring Tech, Arnott Set
lifting setup - McBay Performance, Supreme Suspensions (keys in front and spacers in back - additional question: with a 3 inch lift will I require longer shocks? I heard no from other forum members, but I want to make sure since the ad says yes)
belt tensioner - ??? OEM, Dayco, AC Delco, Dorman..... ???
air filter - OEM, Fram, Wix
Whatcha think?
Thanks in advance
'03 H2 (name: Big Gulp)
