Old 02-19-2015, 05:29 AM
pdxrealtor's Avatar
Default Oil.... synthetic to conventional?
I've been using Royal Purple since 22 or 24k miles. I've noticed though, the I'm going through about a quart every 6-6500 miles. At the price of RP, plus the extra court, I could put conventional in it every 3-3500k and come out way ahead in the cost department.
I wanted to get some opinions first though. Is this OK to do?
Does your H2 blow through the oil? I've read it's a 6.0l vortec issue, so I'm guessing the answer is yes.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 02-19-2015, 07:07 AM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Default Re: Oil.... synthetic to conventional?
I've never had a leak so I rarely check my oil levels but have never had an issue with burning oil. I've always ran Mobil 1 in all my vehicles including the 2.
Typically it is not a problem to switch back to conventional or the other way around. Some will say to mix each oil (same weight) while some sources will say to just do a complete swap. Depends where you read the info.
Old 02-19-2015, 06:06 PM
pdxrealtor's Avatar
You don't burn any oil? I don't have leaks, at all. But I do burn some oil.
If you put 6 quarts in with a new filter- after 5k miles you're dip stick still reads to the top dot???
Thanks for the other info....
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 02-23-2015, 01:18 AM
LoJac963's Avatar
I'll check it tonight. I'm only about halfway to my next change but I'll see what the stick reads.
