Old 11-06-2005, 02:28 PM
BobPri BobPri is offline
BobPri is off the scale
Thanks for the replies on my previous oil change question, 1 follow-up, several of you mention letting the auto oil monitor system notify me when it needs the next oil change. I currently have just over 3000 miles on my new 2006 H3. The system has not told me to change the oil yet, and I understand depending on driving habits & conditions, it can go upwards of 6-10k miles before it tells you to change the oil. However, I have not done my very First oil change yet. Are you saying to let the monitoring system dictate All oil changes including the very first one, or just subsequent oil changes after the 1st is done? I don't want to run it too long and damage the engine since its still running on the original factory oil/filter. Thanks very much.
[Firm:
How often should you take your H3 in for service? They put this sticker on it that says 3,000 miles. However the receipt says 3750 miles.
First Hummer:
Let the truck tell you when it needs oil change.I have 4600 miles on mine and the oil life is at 78% left.
Waxing:
How can I tell how much oil life I have left. You stated that you have 78% left.
First Hummer:
Wax , you can sign up with Onstar to have your vehicle send you an email with a diognostics of your vehicle each month ,thats where it tells you how much oil life you have left.]
[Firm:
First Hummer:
Waxing:
First Hummer:
Old 11-06-2005, 06:24 PM
fourfourto's Avatar
I did my first change at 1400 miles I am still debating to do next one bettween 4,400 miles + 5000 miles on truck or go with the monioring system .If your leasing go by the system if your going to keep it passed 100,000 miles and you change oil yourself cost is low and it has to be better for motor(I mean Engine... motor runs wipers as stated in previous thread).
H3 gray aventure ,sunroof, steps ,roof rack ,smokers package ,window vents, sunroof visor, hard spare tire cover, h3 valve caps , mudflaps and K&N filter 3,200+ miles
Old 11-06-2005, 07:07 PM
Thanks for the reply fourfourto. I think I'll go ahead & get it done now even though the system doesn't say to do so, and then see how it goes from there, making sure I reset the oil monitoring system of course so that its accurate on next change. If it goes over 4 or 5k on the next (2nd) oil change I may also go ahead & just change it since I am doing my own. Something just bothers me about going 6-10k on 1 oil change!
Old 11-06-2005, 07:11 PM
- mine is almost 3,000 miles now and I'm so excited to do my first oil change....
Old 11-06-2005, 07:29 PM
Let me know how it goes Green Lantern, or if you have any tips afterward, I am going to do mine this coming week. Thanks.
Old 11-06-2005, 09:40 PM
2xtreme's Avatar
2xtreme 2xtreme is offline
2xtreme is off the scale
this may be a dumb question but how do you find the % of oil life left. my 2003 silverado had it through the stearing wheel controls. have not been sucessfull finding it on the hummer.
Old 11-06-2005, 10:02 PM
Waxing's Avatar
Waxing Waxing is offline
Waxing is off the scale
As First Hummer told me just call On Star they will e-mail you the monthly the status of you whole truck including the oil % left.
Old 11-06-2005, 10:10 PM
Waxing's Avatar
I'm sorry On Star's number is 1 888 466 7827
Old 11-06-2005, 11:32 PM
2xtreme's Avatar
ok,when OnStar expires then what? is there a way through the driver info. center to get oil life %
Old 11-07-2005, 12:41 AM
Hi-Cap Hummer Hi-Cap Hummer is offline
Hi-Cap Hummer is off the scale
I change oil the first time after 600-800 miles, use Mobil 1 oil filter, Mobil 1 SAE 5w-30 Synthetic oil. Since I drive less than 7,000 miles a year, I change the oil and filter every 6 months in the Hummer and Chevrolet Avalanche. Cost about seventy dollors a year for each vehicle as I do my own work. Cheap insurance!
Old 11-07-2005, 04:05 AM
Waxing's Avatar
2xtreme, I don't know. Does anyone else know.
Old 11-07-2005, 10:39 AM
I believe the change oil light comes on at about 15 percent remaining...can't remember the exact percentage, but it does not come on at zero life left.
I also believe you can read it via a Tech 2, but that does not help people who have not invested in this hand scanner.
This is my oil change schedule. I'm a firm believer in the GM oil life system. One reason, is I know some of the people who worked years on this project, and know the testing they did to confirm their algorithms. However, I will always perform my first oil change at approx. 1-2K miles, and from then on, let the computer tell me when to change the oil.
Only other times I would deviate is if I was running a foam air filter (which I will never do), and off-roading in dirt (especially sand), or if I was submerged in deep water. The computer cannot allow for extra dirt intake and foam filters are noted to do a poor job of filtering dirt when compared to a paper filter; therefore, the computer has no idea how much dirt is entering the engine.
The algorithms for the oil change light are based upon engine operating conditions at startup, how long the engine is run between startups, how hot it gets each drive cycle, and most importantly, the oil you use, and the fact that the engine is as well sealed as it was from the factory.
Oil grade is important. You must use oil that is specified by GM, this is what the algorithm is based upon. It knows how this oil will degrade over a period of time, when subjected to heat, cold, etc. Using a lower grade oil will not result in an accurate reading.
Using an oil that exceeds the specification such as a synthetic oil is ok.
Old 11-07-2005, 01:48 PM
woyster_h3 woyster_h3 is offline
woyster_h3 is off the scale
I did my first oil change at approximately 1400 miles and stuck with conventional oil. Yesterday, with 5000 miles on the odometer I switched over to Mobil 1 synthetic and plan to change it every 5000 miles. It might be a little overkill but like someone else said it is cheap insurance to keeping you engine running like new.
Traded 4-1-06: 2006 Black Hummer H3 Adventure Series - Vortec 3.5L Inline 5
Offroad Suspension Package, 33" Tires, Electronic Fully Locking Differential, 4.03:1 2-speed Transfer Case, Ebony Cloth Trim, Automatic Transmission, Sunroof, Roof Marker Lamps, Fog Lamps, XM Satellite Radio, CD/MP3 Player, Trailering Package, Black Tube Nerf Bars
Old 11-07-2005, 10:02 PM
2xtreme's Avatar
thanks for the info guys
