Old 09-18-2006, 05:53 AM
tattoou tattoou is offline
tattoou is on a distinguished road
Default I need a wiring diagram for a 2003 H2
Anyone know where I can get a wiring diagram or repair manual with one in it ?
Old 09-18-2006, 07:57 AM
Easy Ed Easy Ed is offline
Default Re: I need a wiring diagram for a 2003 H2
http://www.helminc.com/helm/product2.asp?class%5F2=HUM&mk=Hummer&yr=2003&md=Hu mmer+H2&dt=&module=&from=result&Style=helm&Sku=GMT 03N&itemtype=N&mscsid=HNFF0HRRUKXV8G0HWASL0WLHUAA9 AEXA
Old 09-18-2006, 03:12 PM
wiring diagram for what?
Old 09-18-2006, 09:58 PM
I need to find the wires that come off the fog light switch in the overhead consol.
Old 09-20-2006, 11:27 PM
Someone took the fog lights off before I got it, I put some on the brush guard and want to use the switch in the overhead consol, or there is a switch under the tow switch that I can't figure out what it is for.
Old 09-21-2006, 02:32 AM
GONEGOLFING GONEGOLFING is offline
GONEGOLFING is an unknown quantity at this point
If I remember right the wires are routed from the above console (switch) down the driver side A beam. If you pop off the cover on the side of the dash (exposed when the drivers side door is open) You should see the wires they are yellow, purple, blue and black. Mine were taped together. Good luck.
Old 09-24-2006, 12:51 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
With the switch facing up(light on switch facing up) blue wire on bottom terminal, yellow in the middle black on top.
