Old 06-10-2009, 02:28 PM
HumminNBoatin''s Avatar
Default H2 Interior Winch Controller
I have searched all the forums. I have found nothing. So I just might be the first, at least the first to post it.
I thought this layout might work good. Its well within reach for use while behind the wheel.
[IMG][/IMG]
I wired it up. It was very easy.
[IMG][/IMG]
And the final product.
[IMG][/IMG]
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 06-11-2009, 12:29 PM
Rene S. Nielsen Rene S. Nielsen is offline
Rene S. Nielsen is off the scale
Default Re: H2 Interior Winch Controller
Hmmm, sorry not sure I like it, but that's just me.
Maybe overhead console..... Any thoughts
Have been looking for a good solution to have the winch control inside too.
Rene
Old 06-11-2009, 03:21 PM
Very nice. Can it be by-passed to an outside switch?
Old 06-11-2009, 03:46 PM
Rene--I wanted to keep the controlls within reach while having to winch and drive at the same time. Its alot easier to reach controlls where I mounted them than up on the roof console.
Drty... It can be bypassed by the outside controller. The covered switch on the dash has is the 12V Hot. The two push buttons are the grounds that complete the circuit. So you flip the covered switch to "arm" the system. You just T into the controller wire with the hot and grounds. Very simple set up.
Old 06-16-2009, 04:22 AM
tomp's Avatar
tomp tomp is offline
How are you going to ensure the cable is not getting in a bind, if you can't see it while winching?
Old 06-16-2009, 01:01 PM
Tomp - good thinking.
Maybe that's what the holder thingy closer to the window is for, there you put the lcd screen that have a small camera on top of the winch, so you can keep an eye on it from inside your car.
Anyway I do like the idea of being able to use the winch control from inside the car. Right now I roll dwn my window and the cable for the winch control is long enough so I can use it that way, but it dosn't look "clean".
Rene
