09-21-2004, 01:12 PM
The instructions say to install it after the MAF sensor and ahead of the accordian plastic intake hose. The problem is when I do this, and re-assemble, the maf housing which slips into the accordian intake hose, ends up pushing the tornado into the accordian hose too deep where is no longer fits snugly and the tornado turns on its axis.
I was thinking of installing the tornado between the accordian instake hose and the plastic intake duct, but couldn't figure out how to seperate the accordian intake hose from the housing (is it glued on?).
thanks in advance,
Jon
thanks in advance,
Jon
thanks in advance,
Jon
09-21-2004, 08:17 PM
yes it is glued but you should be able to insert a thin bladed screwdriver and gently seperate the accordian from the plastic. just take you're time.
09-21-2004, 10:00 PM
step on foot pedal, thrust into opening, remove foot, crack open a beer, complain you spent $50 on that piece of garbage.
09-22-2004, 12:17 AM
If I were you I would throw that peice of crap out, delete this post and pretend like you never even heard of the TorNOTo like HummerLV said!
09-22-2004, 01:10 AM
Yep--the trash is where it should be.
09-22-2004, 01:26 AM
you'll get more use out of that tornado if you use it as a cookie cutter! That thing doesn't work at all!
09-22-2004, 05:14 PM
Yep, Garbage!!!
(just had to chime in I have 2 of them I purchased @ 2 am)
09-22-2004, 05:24 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Posted by drmiles:
(just had to chime in I have 2 of them I purchased @ 2 am) <HR></BLOCKQUOTE>Step away from the tv and computer after 1am and too many cocktails.  No telling what may show up on your door step.
09-22-2004, 07:55 PM
Ok you guys win, its in the trash.
Jon
Albuquerque '04 Lux
09-28-2004, 12:56 AM
Do you still have the box? Just thinking that maybe you could find something comparable to "dump" into the box to return to them.
10-03-2004, 02:31 AM
I don't know...
I have had some good luck with mine! I went from around 9.5mpg to 11.5mpg with my tornado.
It must be the operator
03\' Pewter Adventure SUV (sold)
05\' Pewter Lux SUV
10-03-2004, 11:18 PM
The question here is why you were only getting 9.5mpg to begin with unless you were towing and driving into a head wind. Did you unhook the trailer when you did the installation?
10-04-2004, 12:35 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by DavidAragon:
I don't know...
It must be the operator  <HR></BLOCKQUOTE>
I get 11.5 with 37's without that junk.
