Old 05-02-2005, 08:03 PM
wannabeH3's Avatar
i need to tow! i need to two dirt bikes, street bikes and utility trailers.. how is the engine? it seems weak to me... does anyone have a link with specs on this H3? has anyone ever driven one yet? what are your thoughts?
(with insurance)
wannabeH3's Avatar
(with insurance)
Old 05-02-2005, 08:50 PM
I would go with a v-8 if you are going to tow more than 3,500 lbs. A small trailer with two bikes is fine but none of the HUMMER line is really sweet at towing. Small load for a small truck is fine. Check specs at hummer.com on towing I belive it is 4200 lbs
Old 05-03-2005, 12:00 AM
funpilot funpilot is offline
funpilot is off the scale
The site says the limit is 4500 pounds but if you want to tow more you need antisway bars. Does not say how much more you can tow. I would also presume you want a trailer with its own brakes above 3500 pounds.
Old 05-03-2005, 04:11 PM
You will need a drop and the antisway for sure and again. I would not plan over 3500 lbs
Old 05-03-2005, 07:03 PM
wannabeH3's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by usetosellhummer:
You will need a drop and the antisway for sure and again. I would not plan over 3500 lbs </div></BLOCKQUOTE>
arent the sway bars included with the towing packages tho?
(with insurance)
Old 05-03-2005, 07:11 PM
The ball drop into the reciver hitch, then the bars from what i remember. it will attach to your trailer. I am not an expert but with out anti sway the damn thing will be all over the place.
Old 05-03-2005, 09:57 PM
H3 Builder's Avatar
H3 Builder H3 Builder is offline
H3 Builder is an unknown quantity at this point
The H3 comes with sway bar on the rear axle. But I think Usetosellhummer is talking about is an antisway atachment at the trailer hitch to help with the trailer swaying.
Old 05-04-2005, 06:22 PM
yea that's the ticket
