Old 01-31-2005, 05:50 PM
guyzilla guyzilla is offline
guyzilla is off the scale
in an '03 H2? I was considering the dash right behind the AC vents but it would be awfully visible to thieves? or right under the ignition but it's kinda hard to see and difficult to release the hatch to make it portable?
Also does the 3M sticky tape used to mount one work well (or too well, will i ever be able to remove the stickum?)
I will not be hardwiring it since i'm afraid of removing the stereo so i will be playing it thru an fm frequency.
Thanks.
Thanks.
Old 02-01-2005, 08:11 PM
ratesguy ratesguy is offline
ratesguy is off the scale
I mounted an xm my/fi in between the center vents and just a bit lower than the vents. It still allows use of the cd changer. The 3m tape works very well. I did not mount the antenna, just rolled it up and put it behind the unit. I get excellent reception just having the antenna on the dash. I worried about thieves but unless you are real tall and the unit is on you cant really see it. I take it in at night.
Old 02-01-2005, 09:31 PM
austoak austoak is offline
austoak is off the scale
I have the small little square tuner that is wired into the H-2 stereo. I have a sunroof so I mounted it up above on the backing of where the controls are for the roof and garage doors. This way you just look up and hit the buttons. I just didn't like the look of it stuck on my dash somewhere. Where it is now you dont even see any wiring nor do you even know its there unless you look up.
Old 02-02-2005, 02:15 PM
Thanks for the suggestions. I believe i have found the perfect place for me to mount it. I took the plastic removeable ashtray cup that came with my H2 that i never used and mounted it to the top of it. I then just simply put it in my front cup holder. I can even lift the plastic lid and put any excess wiring that i may have in there. Easily removable and now i don't have to f'up my dash with glue.
Now i need to find the best/easiest way to run the antenna wire from the cup holder, under the steering wheel, and somehow around the window siding for a rooftop antenna mount about a foot behind the onstar antenna? I can't get the damn wire to stay tucked into the window/door trim and i don't think small pieces of tape will stick for long?
Old 02-02-2005, 02:17 PM
Spike Spike is offline
I just picked up the Sirius Sportster last night. $129.00 at Circuit city complete with car dock, antenna and cigarette lighter power cord. If anyone has pictures of a portable satelite radio install please post them. Here is a picture of the unit I got.
Old 02-02-2005, 06:46 PM
Satelite radio is installed, up and running. Installation was a breeze. It took me longer to decide where to put the unit than the actual install. I'll post pictures in a few minutes.
Old 02-02-2005, 07:05 PM
OK gang, here it is. Sirius Sportster Plug and Play Satelite Radio. It truly is plug and play. I didn't need any tools for the install except 1 phillips head screwdriver to screw the docking bay to the mounting base. I mounted on the dash to the left of the steering wheel. This way it did not impede my vision. I tried it in the center above the 2 vents and it does impede your vision to some extent.
Old 02-02-2005, 07:09 PM
Close up view
Old 02-02-2005, 07:10 PM
Antenna mount on roof
Old 02-02-2005, 07:11 PM
Another angle antenna mount
Old 02-02-2005, 07:13 PM
I ran the antenna wire up inside between the rubber moulding and the headliner up the entire driverside of the vehicle.
Old 02-02-2005, 07:14 PM
Then I removed the pillar garnish and ran the wire down that and out the bottom to the unit.
Old 02-02-2005, 07:17 PM
where wire came out from pillar garnish and goes into unit
Old 02-02-2005, 07:18 PM
Next I ran the power cord into the same opening as the antenna wire but then ran it down the side of the dash behind the acess panel
Old 02-02-2005, 07:21 PM
Then I ran the power cord across the bottom of the dash around the base of the center console tucking the wire in where the console and the carpet meet.
Old 02-02-2005, 07:22 PM
Then I ran the wire behind the foam between the console and the dash and out in the middle and into the cigarette lighter plug.
Remote
Old 02-02-2005, 07:23 PM
Fits perfectly in console recess
Old 02-02-2005, 07:27 PM
I activated the service online and it was working in less than 5 minutes.
Now I have to go gas up so I can sit out in the truck and listen to it.
