Old 02-06-2006, 11:04 PM
Today I settled on which aftermarket warrant I'm getting. I've checked out about a dozen different companies and have narrowed down to 2 companies. (one being Warranties 4 wheels brokering it to a company called Great Lakes)
My biggest problem is most of the warranties I looked at end at roughly 50K miles. Great Lakes has 48 months but unlimited mileage.
This company I'm signing up for tomorrow has added the same "electrical" and will change the mileage to 100,000.
There is no deductible and the total cost is 2500 bucks.
If anyone is interested, let me know, I'll give you the guys phone number. After being in the automotive business for over 20 years, I was most comfortable with what this guy had to say.
COVERED COMPONENTS
v Engine: All internally lubricated parts of: pistons, piston rings and pins, crank shaft and main bearings, connecting rods and bearings, camshaft and bearings, timing gear chain and/or belt, rocker arms, shafts and bushings, valves, valve springs, guides and seats, push rods and lifters, oil pump. Externally: water pump, mechanical and/or electric fuel pump, oil pan, flywheel, valve covers, engine mounts, intake and exhaust manifolds, distributor shaft, gear and bushing, engine head(s), engine block, gaskets and seals if damaged as a result of failure of covered engine parts.
v Transmission: All internally lubricated parts contained within an automatic transmission and transfer case inclusive of: clutches, bands, pumps, carrier assemblies, internal shafts, (main, intermediate, reaction), thrust washers and bearings, governor, valve body, servo and accumulator assemblies, torque converter, transmission mounts and shift linkage, throttle valve cable, case if damaged as a result of failure of covered automatic transmission parts, internally lubricated parts contained within a manual transmission inclusive of: main shaft, coupler shaft, all gears, synchro hub assemblies, bearings, shift rails and internal shift forks, input shaft synchro rings and retainers, case if damaged as a result of failure of covered components. Internally lubricated parts within the trans-axle of a front wheel drive, including ring and pinion gears, internal bearings, axle(s) and case, if damaged by covered components.
v Rear-Wheel Drive: Parts contained within the differential housing, including ring gear and pinion gears, bearings, differential housing if damaged by failure of internally lubricated parts, axle, and universal joints.
v Four-Wheel Drive: Parts contained within the transfer case; transfer case if damaged by failure of internally lubricated parts.
v Air Conditioning, Cooling and Heating: Factory installed compressor, clutch, heater core, blower motor, radiator, fan, and fan pulley.
v Electrical: Starter, starter solenoid, alternator of generator, voltage regulator, windshield washer pump, wiper motors, trunk lid motor, engine control computer, ignition control module, blower motor, power seat motor, door window motors, power mirror motors, speedometer, tachometer, oil pressure gauge, water temperature gauge, electronic control module (ECM/ECU), climate control, Power train Control Module (PCM).
v Sensors: Manifold pressure temperature, throttle position, mass airflow, coolant temperature, vehicle speed, camshaft/crankshaft angle, wheel speed and climate control sensors.
v Steering: Steering gear, power steering pump, steering column shafts and coupling, rack and pinion.
v Brakes: Master cylinder, vacuum assistant booster, emergency brake cable, brake calipers (loaded), (ABS), wheel cylinders, compensating valve, brake line tubing and fittings.
v Front Suspension: Upper and lower control arms, control arm shafts, upper and lower ball joints, tie rod ends, constant velocity joints, axle(s) wheel bearings.
v Wear & Tear: Any covered part listed. If it breaks due to excessive wear, or is worn out.
v Seals and Gaskets: All seals and gaskets are covered in conjunction with covered parts.
v Labor: All necessary labor will be paid by AUTO REPAIR WARRANTY, INC. to repair or replace all parts covered under this warranty agreement.
v Rental: If a vehicle requires more than a 24 hour period to be repaired, AUTO REPAIR WARRANTY, INC. will pay up to thirty dollars ($30.00) per day for a maximum of up to four (4) days.
v 24/7 Roadside Program: Towing, emergency tire, battery, gasoline and lockout service, emergency transportation up to 150 miles.
v Trip Interruption: If a vehicle requires more than a 24 hour period to be repaired, AUTO REPAIR WARRANTY, INC. will pay up to four (4) days at $50.00 per day, (over 200 miles from home).
INELIGIBLE VEHICLES
Trucks over one ton classification, taxis, buses, law enforcement vehicles, motor homes. Vehicles used for delivery, construction, taxi, rental, or racing competition. Vehicles modified from the manufacturer’s original specifications, Salvaged vehicles, vehicles equipped with a snowplow, vehicles with inoperable/inaccurate speedometers or odometers. Cadillac’s equipped with 4.1 liter engines. Vehicles with 3, 10, or 12 cylinder engines. Any and/or all vehicles used for plowing. Any and all vehicles used for towing. Any commercial use will invalidate this warranty.
DEFINITIONS
Pre-existing: Pre-existing conditions may be defined as, but not limited to: any part that was broken was worn beyond serviceable limits, or making noise at the time of purchase. Any component or system that was not functioning properly upon the first attempt to operate is also considered pre- existing and includes, but is not limited to: four wheel drive, air conditioning, and electrical components. Failures or breakdowns resulting from pre- existing conditions are the responsibility of the service agreement purchaser.
Mechanical Breakdowns: The inability of any Covered Component to perform the function for which it was designed due to defects in material or workmanship. Mechanical Breakdown does not include the gradual
This is the electrical they are adding...
ELECTRICAL: (Factory Installed Only) Alternator
housing and all internal parts including bearings,
bushings, brushes, rectifier bridge, diodes, field coil and
rotor; alternator mounting brackets; voltage regulator;
starter motor housing and all internal parts including
bushings, field windings, starter drive and solenoid; front
and rear wiper motor and linkage; power window motor;
power seat motor; headlight switch; wiper motor switch;
mirror motor switch; stop light switch; neutral safety switch;
glove box light switch; courtesy light switch; cooling fan
relay; air conditioning solenoid; air regulator valve;
electronic ignition module; electronic instrument panel
module; ignition coil; distributor modules; throttle position
sensor; vehicle speed sensor; map sensor; knock sensor
and barometric pressure sensor; engine distributor
including shaft, gear, bushings and module; cruise control
components including module, servo, cables,
engagement switch, electronic instrument clusters and
driver information systems including speedometer,
odometer, tachometer and warning indicators; theft
system and keyless entry transmitter, keyless entry control
unit, receiver/module. Door lock actuators; mirror motor;
power window switch; power lock switch; turn signal
switch; brake light switch; horn and relay; convertible top
motor; sun roof motor; power antenna motor; electrical
head lamp motor; power trunk/hatch release solenoid;
front and rear window regulators;crank angle sensor;cam
position sensor; automatic temperature control sensor;
mass air flow sensor; coolant temperature sensor, O2
sensors.
