Old 02-20-2004, 12:29 AM
AZhummer AZhummer is offline
AZhummer is off the scale
Hi All, I have a question. I would like to get larger tires. 37's ( 36 really ) I wonder if one of you guys who have this size on there H2 can give me the low down. Is the rear end ratio change noticable? Goes from 410 to 390. Is the highway handling and stability different? What do you think?
03 H2
03 H2
03 H2
03 H2
Old 02-21-2004, 09:52 AM
Bevo Bevo is offline
Bevo is off the scale
Actually, going from stock 35's to 37's changes the ratio the other way... s/b from 4.10 to around 4.33. 37/35*4.10=~4.33...
[This message was edited by bevo on 02-21-04 at 04:11 AM.]
[This message was edited by bevo on 02-21-04 at 04:12 AM.]
Yellow 03 Adventure w/black Grill, UM8 Touch Screen Navigation Radio, U2K XM Digital Radio, Remote 6-CD Changer, JBA Titanium Headers, Corsa Off-Road Sport, Airaid Filter & MIT, Nology Wires & Plugs, S&P Pro-Flash, Warn 9.5ti w/X-Line, Toyo Open Country M/T 37x13.5.
Old 02-21-2004, 12:29 PM
I think the formula is old size/ new size. Not new size/old size.
03 H2
03 H2
Old 02-22-2004, 12:10 AM
At 60 mph you will be going 63.4 with 37" diameter tires.
http://www.chrismans.com/Calculators.html
And this from http://www.4x4connection.com/gearchart.htm
According to this chart, the acceptable RPM range is 2000-3000 which is represented by the entire shaded area of the chart. The optimum RPM range is 2300-2600, and is represented by the light yellow shading. When changing ratios to improve mileage, choose a ratio within the dark yellow shaded band below the optimum range.
Black Lingenfelter Lux
Old 02-22-2004, 07:53 AM
AZ,
Check out the link to Crismans that KenP mentions in his post. They have several online calculators that will help you out.
Old 02-22-2004, 02:04 PM
Navigator is off the scale
I remember reading a very good (long) detailed post about this it may have been from Mac, I could not find it with the search though. Maybe someone else will remember it.
Rich
04 H2 Adventure Series
Rich
Mods & Pics
Old 02-22-2004, 02:22 PM
Rich,
You've gotta be kidding. Mac writing an informational post about something technical. Impossible!
Old 02-22-2004, 02:23 PM
Bevo, you are correct, I don't know where I saw that other formula. Wow 4.33 would give better acceleration and the increase in speed would in effect give the same results as the stock tire size. But you will gain 1 inch diff clearance. That is my goal.
03 H2
03 H2
Old 02-24-2004, 12:26 AM
Apex IV Apex IV is offline
Apex IV is off the scale
I have 37 x 13.50 x 17's on one of my H2's, 37 x 12.50 x 17's on another and the other two have stocker tires. The 37 x 13.5's are about an inch and a half taller than the BFG 37 x 12.50's and about that much wider. I've been out of the country for a while, which is why I have not been able to post, but if you search by my user name (apex4), you may find some pictures I posted when I installed the 13.50's. I live in a moderately hilly area, so I notice the change in "effective" gear ratio with both of the 37's - more so on the 13.50's (they are actually taller than the BFG 37's and wider, so they also weigh considerably more.) We did the intake/chip/exhaust on all four H2's and that helped some, but not enough on the ones with 37's. Ended up supercharging one with the larger tires and one with the stockers - Big improvement and about 3 mpg better on the one with 37 x 13.50's. Slight decrease on the one with stock tires. Both more fun to drive... :-)
Hope this helps!
-Randall Garrett-
Apex Software
----- END -----
Old 03-07-2004, 05:23 PM
It\'s a Dry Heat's Avatar
Warranty policy per Doug Hamlin at AMG:
BODY LIFTS: will not void your factory warranty BUT a body lift will "red flag" your truck, so any warranty issue will be reviewed and IF it is determined that the body lift had anything to do with your warranty claim, it will be denied.......the factory claimed that a lift increases "body roll" and the center of gravity...thus......claims on idler/pitman/ball joints/t-case/ect....you may be in for a "debate" with the factory
MILE MARKER HYDRAULIC WINCHES: AMG will NOT pay for warranty claims on the P.S. pump, the steering gear box, or the hydra boost if you have the MM-hydraulic winch.
TIRES over 37 inches: same thing, a debate if they think the tires are related to the claim.
Vern
04 Yel H2, F&R Eaton lockers, SMA HD brush guard, XD9000i, Auto Start. Garmin StreetPilot 3.
